Tricks for removing radius arm mount from axle? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-06-2006, 01:14 PM   #1 (permalink)
Member # 68041
I got a 68 ford pickup with a 9" and a HP44 and will be just using the axles for my toyota. I was curious if anyone has little tricks for getting the radius arm/coil bucket mount that is on the axle off. I am using leaves, so I won't be needing them for anything. I would just leave them on, but they are kind of rock anchors on the bottom, and I believe my springs are going to hit part of them. Thanks a bunch.
When you need it, and don't have it, you'll sing a different tune.
ZombieFan223 is offline   Reply With Quote
Old 11-06-2006, 01:26 PM   #2 (permalink)
Member # 4438
Angle grinder. Cut through the welds and knock them off with a BFH.
Those who dare, win. Wish I had a Tuesday filter.
afecko is offline   Reply With Quote
Old 11-06-2006, 02:10 PM   #3 (permalink)
Member # 72575
Yup, get the grinder out. Make sure you grind horizontally towards the weld and not at an angle into the weld. This way you don't cut into the tubes. Once you get most of the weld grinded away a sledge (BFH) will bust it the rest of the way off.
68 Bronco:302, NP435, NP205, HPD60, D70, 5:13 Gears, Detroits, Drive Flanges, Yukon 35 Spline Axles, 5.5" Cage Lift, 38" SSR, TR Bead Locks, 98" Wheel base, Stone Crusher Steering, Ram Assist, 1350 Drivelines, 3/8" thick Diff Covers
68Broncoholic is offline   Reply With Quote
Old 11-07-2006, 12:57 AM   #4 (permalink)
Member # 40162
If you can get them off without damaging them, I might want them-pm me
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote
Old 11-07-2006, 03:29 PM   #5 (permalink)
Master Apprentice
Member # 56692
You need to cut in at a slight angle or you wont seperate the weld from the tube, cut in at a slight angle and check often to make sure your not in the tubes. Do both sides then smack with a very large BFH.
It may help to heat one side with a torch then apply BFH, but I didnt have a torch so I couldnt try.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks
sn0border88 is offline   Reply With Quote
Old 11-07-2006, 03:53 PM   #6 (permalink)
Member # 56006
As everyone said there just welded on...Take your time taking them off dont damage them...They are in high demand for some of us Ford guys...
JoshTurner is offline   Reply With Quote
Old 11-08-2006, 10:25 PM   #7 (permalink)
Hyde's Avatar
Member # 53554
Oh and one quick thing, hope you aint using you pass. side drop t-case
I break stuff.
Gearing is a crutch for lack of horsepower.
Hyde is offline   Reply With Quote
Old 11-13-2006, 08:36 PM   #8 (permalink)
SMC
SMC's Avatar
Member # 8941
James Duff:
Axle Wedges
For the Bronco owner that is swapping front axles, these wedges make it much easier. No need to cut up a good front axle just for parts. These wedges are designed to weld onto a 2 3/4” O.D. tube, just like a factory Early Bronco Dana 44 but are easily modified to fit onto 3” O.D. tubing found on high pinion Dana 44 and Dana 60. Cast with all the correct configurations to fit the inside of a C bushing exactly like original.
#5340 Axle Wedges, $85.00
http://www.jamesduff.com/eb/suspension_components.html
I have never seen such a ruthless bunch of people til i came on pirate... - hawkins1
SMC is offline   Reply With Quote
Old 11-13-2006, 09:48 PM   #9 (permalink)
BnTMike's Avatar
Member # 197
I cut the c off on the inside of the weld and then blow the remainder off with the smoke wrech... they are not welded on the sides. I quit grinding the weld after the 6th or 7th axle...you can re use them still to. WAYYYYY FASTER!!! JMO
Mike-
LADD Racing #82 NCRR and 2014 KOH-EMC
Mike Ladd and co dawg Perry Hemre
Club Jackass Wheelers
TTC 1999
BnTMike is offline   Reply With Quote
