Member # 59962
1984 Ford Transfer Case
I am about to go look at a 1982-1984 Ford 1/2 ton stepside 4x4 w/ a 400 small block in it stock. What transfer case and axles are under it...typically or where can I find the info?
#2 (permalink) | |
Member # 28687
Either a Dana 44 or Dana 50TTB, Dana 70 (or 61) rear, and either a NP208 or BW1345. |
Member # 14848
the ford 400 in not a small block, and as stated above, it is most likely a 208.
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case 1988 Bronco,in progress |
#4 (permalink) | |
As for the question at hand, its probably a 351M. If its an F-150 as stated, it will have a D44 TTB front axle, 8.8" rear axle. It could be either a BW1345 or NP208 transfer case.
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet Last edited by VerticalTRX; 11-09-2006 at 05:22 AM. |
Fawkin Fordhead
A 351M or 400 is a 335 series, yes, different bellhousing pattern than a 351C on most, and shittier heads and a taller deck, but, still the same family... Last I checked Ford didn't use small block and big block classifications...
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build Last edited by 82F100SWB; 11-09-2006 at 10:28 AM. |
Member # 44404
A little ford motor info for those who care. http://www.answers.com/topic/ford-335-engine
The 400 came with a SB bell pattern for one year in 74! The pre 84 trucks should still have a 9 inch axle. I believe 84 was when ford started to swith to the 8.8 and the 9 could still be found as late as 86. |
