Member # 9381
Track Bar Bushing
I am having some trouble with my track bar bushing. They don't last very long. I have 35 boggers and no lift locked front and rear. Anyone else have these problems and what is the best way to fix it? Just replace the bushing now and then or is there a better solution?
says "yall" alot
Member # 13671
Make a new mount on the axle and run a heim on the axle end. This will at least mean you only have to replace one bushing instead of two.
Is your front moved forward/backwards? Looking at the truck on level ground, does the bar itself appear to be inline and no bind on the bushings? Are you cranking everything down too tight? Ive beat the crap out of mine for 5 years on a set of poly bushings before they ever needed replacement so id say you have a problem somewere...
Hey kid, are you going my way? Hop in... we'll have ourselves a field day |
#3 (permalink) | |
Ford Bigot
Member # 31227
My EB used to eat trackbar bushings annually. I would upgrade to heims and never look back.
Project Flat F***er (Fender) Project SR5.0 |
Member # 9381
It is specificly the bushing on the top end by the box. After a month or 2 of wheelin it just gets a lot of play in it.
Where is a good place to get some heims from, and what should I be looking to spend for some? |
Member # 72575
Yeah, I always had problems with the upper bushing failing and went with heims both ends.
In the porcess I raised the axle end and ditched the drop trac bracket. Then did tie rod over coversion.
68 Bronco:302, NP435, NP205, HPD60, D70, 5:13 Gears, Detroits, Drive Flanges, Yukon 35 Spline Axles, 5.5" Cage Lift, 38" SSR, TR Bead Locks, 98" Wheel base, Stone Crusher Steering, Ram Assist, 1350 Drivelines, 3/8" thick Diff Covers |
Member # 9381
Well ok, I found a place to get them, what size and strength should I try to get for the track bar. The truck is not lifted but my get lifted a little like 2-3 inches and is locked with 35s
#11 (permalink) | |
Ford Bigot
Member # 31227
Bulletproof makes a drop in trackbar out thickwall DOM tubing. I recommend doing that if you are not confident in your fabrication skills. I believe Stonecrusher also makes trackbars.
#13 (permalink) | |
Member # 9381
I was kind of looking over both of those websites, and they have some good looking products. i think I'm almost to the point of needing to replace my tie rods and if i do I think I might just buy one of those whole kits. I think it would cost me almost as much to go down to my local parts store and get all the tie rods new. Thanks For The Info |
#14 (permalink) |
Member # 6052
My dads been using the Bulletproof for 5+ years and 45,000 miles with no problems. Drives it thousands of miles from Canada to Baja. All the heims are still tight. He uses their tie rod, draglink and track bar.
'73 Bronco Growing pile of parts. 4 years is long enough! |
