Member # 54093
9" w/ 5x4.5" bolt pattern?
Did Ford ever have a narrow 9" rear with the 5x4.5" bolt pattern in any of there vehicles? If so, what should I look for?
'91 Cherokee #4676 Thanks to: SinisterDiesel.com RuffStuffSpecialties.com RDMOffroad.com |
Master Apprentice
Member # 56692
I just threw one out, it was 58" WMS, 28 spline drum brakes. I dont know what it was orig from but it had 4 link mounts and coil buckets. I got it from a trailer that was the back half of a pickup bed.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks |
Member # 80230
i think fairlanes and all the V8 cars came with them IIRC. look for a lincoln and get one with disc brakes :-) although it'll have some TALL gears in it. them old boats always ran like 2.80's or something like that...
#7 (permalink) | |
Member # 44404
99% of the time the cars will have a 2.80 ratio. The versailles is common to have a 2.45 gear. |
Member # 31769
65 to 73 mustangs fairlanes torinos comets ford granada V8 cars mercury monarch V8 and of coarse lincoln versailles all had them. The fullsize cars did as well but were wider
NORCALBRONCOS.COM |
Member # 54093
alright, thanks guys, so if i want disk brakes, i need to go for a lincoln?
Member # 31769
Unless you get lucky and find a monarch or granada that came with them, LOL
The lincoln is probably your best bet. There are tons of them in the wrecking yards, Like pick n pull
NORCALBRONCOS.COM |
#12 (permalink) |
Member # 77599
If you get a big bearing housing you can run explorer discs with a little modification. 2nd gen explorers are showing up in the yards here every once in a while, or you can buy the kit for about $350. If you don't need a parking brake you can fab up your own for very little.
I think you'd be money ahead to go either route I mentioned vs going versailles. They are heavy, expensive and don't really work that well.
Eric 75 Wagoneer 454/th400/NP205 (looking for the 205, got one in So Cal?) |
