79 ford switching to diesel - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2006, 06:58 PM   #1 (permalink)
Member # 81572
Send a message via AIM to 79 super f150 4x4 Send a message via Yahoo to 79 super f150 4x4
warner t18 trans in a 79 ford want to take out the 351 m and put in a 6.9 thinking the bell from the 85 diesel is the same but thinking the ratio in the transmissions are different not to many folks out there going from gas to diesle its usually the other way around any body out there done it give me some info thanks
79 super f150 4x4 is offline   Reply With Quote
Old 11-12-2006, 07:09 PM   #2 (permalink)
Member # 82063
never seen it done, should be nice after its done though
catatonic is offline   Reply With Quote
Old 11-13-2006, 11:35 AM   #3 (permalink)
Member # 4438
The T-19 behind the 6.9 has a 4.1 first gear. The pattern is the same as a T-18, the standard Ford "butterfly" pattern. Input shaft splines are the same. One area of uncertainty is the input shaft length. IDI (and maybe DI) diesels use a 1" spacer/adaptor between the block and bellhousing, so that may or may not mess with the input shaft length. I would check with AA on that.
Those who dare, win.
afecko is offline   Reply With Quote
Old 11-13-2006, 03:12 PM   #4 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
There's no difference in input shaft legnth, along with that 1" thick adaptor, the flywheel sits back an equal legnth. The diesel T19 still has the same 6.5" input shaft stickout common to most other ford 4 speeds. The diesel trans may have the 5.11:1 first, which is followed with a pretty decent ratio spread for that engine. Maybe take a trip over to www.oilburners.net I think that there may be at least one member who has done that swap.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... [URL="http://www.pirate4x4.com/forum/showthread.php?t=853402&highlight="]Build[/URL]
82F100SWB is offline   Reply With Quote
Old 11-13-2006, 07:35 PM   #5 (permalink)
Member # 81572
thanks for the info i measured everything and looks like everything will bolt together just half to change the motor mounts out ofcourse see how it goes in a few days should have a nice little toy to play with
Old 11-14-2006, 06:48 AM   #6 (permalink)
FF3PM's Avatar
Member # 46229
There are quite a few gas to diesel conversions being done now days. There is a site called cumminsconversions.com or something close to that. They have a lot of onfo on all kinds of diesel conversions.
FF3PM is offline   Reply With Quote
Old 11-14-2006, 10:10 AM   #7 (permalink)
Trckmagik's Avatar
Member # 25418
This may help you:
www.fordcummins.com
Brian Green
[URL=www.NukinFutz.com]www.NukinFutz.com[/URL]
Trckmagik is offline   Reply With Quote
Old 11-14-2006, 11:15 AM   #8 (permalink)
Member # 63546
He's putting a 6.9 in it. Not a cummins. How the hell would fordcummins help? Anyways, I'm sure it will work out fine. Just get goin on it and you'll figure it out then.
mooktank.com -->Cummins B3.3 Explorer Blog
mooktank is offline   Reply With Quote
Old 11-15-2006, 05:00 AM   #9 (permalink)
FF3PM's Avatar
Member # 46229
I found that site I was talking about.
http://www.cummins-conversion.com/photos/index.php
Old 11-15-2006, 07:40 AM   #10 (permalink)
Trckmagik's Avatar
Member # 25418
It will help him to know that he is not alone. A lot of folks install diesels in place of their gas engine.
Read the first post:
"not to many folks out there going from gas to diesle its usually the other way around any body out there done it give me some info thanks"
Brian Green
Old 11-15-2006, 11:56 AM   #11 (permalink)
Member # 50539
Send a message via Yahoo to hammerman94
I have an 85 ford diesel with 64,000 on the motor. I need to sell it. The only thing missing from the truck is the axles. Shoot me a pm if your interested....
94YJ and 85 FJ60
hammerman94 is offline   Reply With Quote
