#126 (permalink) |
heres some pics of its maiden voyage on a hollister shake down run
(WHITE RHINO)88 Ranger, 2.9liter,1350/1354 doubler, HP 60 with Plated knuckles, chromos, PSC Hydro, 3 link, Rear Eaton 44" Pitbulls on H1's Section8Krawlers.com Extreme Dual Sport Tuff Lites Unbreakable Turn Signals for your Dual Sport/Adventure Bike |
#128 (permalink) |
yeah that was the first trip on my new set up back in october i think my bro was being a deuche bag and i finally go the pics from him
#129 (permalink) |
Member # 42546
Sorry if I missed it some where but how wide is your ft end outside to outside of the tires and what offset are the h1s
I have some full with axles and H1 rims but don't want to be much wider that I'm now w/eb axle and 3 1/2 offset rims and 33's |
#130 (permalink) |
my axle is 65 WMS and i run i think 4 inch backspaced h1's im not sure the total width but its not to crazy wide my tires are 38x14.5's
#132 (permalink) |
i just had a ball joint wear out thats it so far ive been beating on it pretty good and no axle shaft problems i have stock shafts with new hd u-joints when i first built it i thought i would would be breaking shafts and hubs but nada
#133 (permalink) |
so i got the ball joint in and all that shit and put the k&N intake on that i got for free im gonna make some mud flaps cause cops in my down are assholes i got a big copenhagen floor mat for retail stores from my boss so im going to cut it in half and run them.
#134 (permalink) |
I just picked up a 92' Ranger extended cab shortbed for free with clean body panels and doors anyone have any tips on a cab swap?
#136 (permalink) |
mines pretty stable i try to keep alot of tools and shit to keep weight on them and they flex super good
#137 (permalink) |
so no one has any tips on cab swaps??????????????????
#139 (permalink) |
Member # 27087
you'll have to cut out the back for the kick-ups on the frame, and maybe the cab corners for your tires...i forget your wheelbase.
just tryin' to figure out how to build this thing! |
#140 (permalink) |
need someone to tell you how to change your diaper also? or u just looking for attention because you have the best ford ever?
step 1 get beer and friends step 2 drink beer and wrench and pull stuff apart, step 3 pull body off step 4 put cab back on and connect whatever you undid. thats how i see it getting donem its not rocket science where you need instructions, its simple to do, even my half retarded friend did a cab swap himself without using the interweb to tell him what to do
1 Ton TJ(ish) Buggy on 40's |
#141 (permalink) |
yeah beer will be part of the equation i will prolly do a 1 inch body lift my buddy mario did it and it makes working on everything alot easier under the rig i was just curious if there was a ton of difference between the computer set up between an 88 and 92 i know that 92's have the 2.9liter just trying to see if anyone has done it on here that might have had some weird problem and answer so i dont have to deal with that shit when im doing the swap
#142 (permalink) |
#143 (permalink) |
Wow....that thing is lookin sick...pretty much what I wana do with mine. On you cab swap, the rear cab mount on my extended cab is built into the leaf spring hanger if that helps at all.
I got a question though as well. I got a Dana 44 housing from a 78-79 bronco and I want to know on yours, what did you do to convert it over to 8 lug stuff and still have hi-steer? Do you just take everything from the knuckles out off of an old F250? Are the F250 knuckles from 76-79 HD Dana 44s able to have hi-steer ran on them? Reason I wana run 8 lug is because I have a Corporate 14 bolt for the rear that my buddy's Dad is practically giving me and if I can go 8 lug now, I'd love to so that in the future, I don't have to re-buy rims and tires if I decide to go with a Dana 60. Zach
SUPPORT YOUR LOCAL FIRE DEPARTMENT |
#144 (permalink) |
yeah i assumed id have to add another body mount which wont be bad
as for the axle i swapped out everything to 79 f250 flat top knuckles which were drilled and tapped by parts mike i think my buddy got it done then sold them to me i run dual piston calipers also which is nice it stops on a fucking dime now which is awesome way better than stock it also drives better on the road than the TTB i would just get 8 lug outer knuckles and brakes and swap it straight over
#145 (permalink) |
Moderator
Member # 5861
Looking good man! I think teh cab swap main not be that bad, Tehre si a F250 posting here somewhere with more info on that. I can not remember, but the guy that has his vison impaired (white ford on one ton's) dis something similar.
#146 (permalink) |
yea i saw it a few months back and cant find it oh well
#147 (permalink) |
Your truck is neither white, nor a rhino. Besides, if you were honest, wouldn't you call it "White Wino"?
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] |
#149 (permalink) | |
#150 (permalink) | |
I didn't bash in the slightest, but I could start if you want
