Member # 9381
Building a track bar?
Well I think I'm to the point that I need a decent track bar. I would like to go with the kit from bullet proof but don't have the cash right now, so it looks like just the track bar.
My question is, which heims to go with? I have been looking around, but not sure if there is a specific size that I should use or one that works better or even one that I need to stay away from. Its going on a 78 F150 with 35 boggers, locked front and rear. No Lift. What are your thoughts? |
do you mean anti wrap or trac bar as in pan hard bar
(WHITE RHINO)88 Ranger, 2.9liter,1350/1354 doubler, HP 60 with Plated knuckles, chromos, PSC Hydro, 3 link, Rear Eaton 44" Pitbulls on H1's Section8Krawlers.com Extreme Dual Sport Tuff Lites Unbreakable Turn Signals for your Dual Sport/Adventure Bike |
Member # 39734
I run a right hand 3/4"x3/4" hiem and a left hand 3/4"x3/4" hiem (for adjustment) from my local circle track shop with tapped 1.5" dom .120 sidewall. This is on a EB with 38's.
Idiot |
#6 (permalink) | |
Maybe im stupid or something, but how in the he** did you tap 3/4"-16 threads into a 1.26" hole? 1.5" - 2x 0.120" = 1.260"anyhow, I think that the stud that is currently on your axle is 1" in diameter, so might want to try to get a heim with a 1" bolt hole so you can use that stud. then just get one that fits on the bolt at the other end to, make the bar to match the heims, im not sure what size the upper bolt is Last edited by blackcloud; 01-10-2007 at 08:02 PM. |
Member # 9381
That's kind of what I was thinking. I new that one on the axle end was larger, I was just figuring they changed some out to run the 3/4 on the axle end.
Now my next question. Is it nesassary to use a new tube or can I use the original bar without any problems by just cutting the old ends off. The only reason I ask this is because I am not familiar with all the tubes and different sizes. |
Since you guys are letting things slide in the newb category, and since I'm about to build a pan hard bar myself...what would be the point of running a LH and RH heim?
I'm not stuck, I'm temporarily stationary. 91 Xsport, 60's, doubler, 39.5s |
#11 (permalink) | |
Member # 39734
"WELL EXCUSE ME" for redoing my roll cage right now and typing the wrong tubing size!! The tubing on my steering and trac bar is 1.25 with .250 wall, this you can tap. On my EB dana 44 the stud is close to 3/4" so the hiem slide right on, and my upper drop bracket is made from 2.5"x2.5" square tubing that I welded onto the frame and drilled the hole for the 3/4" bolt ( them cut some of the tubing to make spacers 2.5" - 2x0.25" - 1" = 1" / 2 = two 0.5" spacers). As for running RH and LH hiems, this is so you can adjust the bar with out having to unbolt it from one of the ends to adjust it. Just loosen the jam nuts and get a pipe wrench. You guys beat me to the adjustment part.
Idiot Last edited by GWBronco; 01-11-2007 at 07:20 PM. |
#12 (permalink) | |
Member # 52872
#13 (permalink) | |
Member # 9381
How about my question, seeing how it is my post thanks |
#14 (permalink) |
Member # 42205
I think if you are going to improve your track bar that you should go get a good stout new piece of tubing that will exceed factory specs and engineering. Get rid of the factory track bar and put something superior in its place.
#18 (permalink) |
Member # 52872
The bolt for the lower mount of the track bar is a 3/4 bolt. I would suggest staying with your trac bar and installing rod ends on it. The trac bar has a S shape to it to clear the front pumpkin, A straight new piece of tubing might hit. Unless yoou have a good lift in it then not as big of a prob, but U said U don't.
Curious to know How often your going through bushings, If U have no lift and your trac bar is paralell to your drag link some good urethane bushings should last a while. |
#19 (permalink) |
Moderhater
Member # 16980
make this, or lemme build you this:
this is on my truck
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
#20 (permalink) |
Member # 52872
sweet gimme more info on that bad boy, so it pivots on one end...
![]() Edit: but what a bout the bend in the stock arm to clear the pumpkin' not an issue in a stock lift? Last edited by grasshopper77; 01-12-2007 at 07:46 PM. |
#21 (permalink) |
Moderhater
Member # 16980
![]() either im a dumbass for looking at the thread wrong, or we're talking about the panhard bar on the front of the truck? this is a traction bar for the rear end of the truck...lol my truck basically has no lift. i use the stock bar, and it works great. only mods i have done is gone to poly bushings, and i drilled out the upper mount on the frame to a 1 inch bolt, because my holes were wallered out big time, and i didnt feel like welding up a new one. plus i had a 1 inch grade 8 bolt hanging around for whatever reason
#22 (permalink) | |
Member # 52872
Yah we are talkin about the front trac bar or panhard bar, he keeps going through bushings and wants to upgrade..
#23 (permalink) |
Moderhater
Member # 16980
after my bushings upgrade and 1 inch bolt, its been groovy
they also make that repair thingie for the lower bolt on the axle, due to slop wearing it out.
#24 (permalink) | |
Member # 52872
![]() edit; whooops I Quoted myself I guess I am laughing at my self nevermind... Last edited by grasshopper77; 01-12-2007 at 08:38 PM. |
#25 (permalink) |
Can you make me one of those bad boys? I can't wait to put this fawker on my front axle as the track par. IT's gonna be so solid nutin's gonna be movin.
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home. |
