#302 (permalink) | |
wow.....so I'm not the only one wasting money apparently in "other places".......makes me feel better about leaving that "other place" at the end of the nite knowing you spend money at these sort of establishments as well....
SUPPORT YOUR LOCAL FIRE DEPARTMENT |
#304 (permalink) |
This build is awsome! I love that body style ford.
Nice welding! Can't wait to see some action shots!
--- 80 Proof --- TJ Juggy Build "14 Bolt don't give a shit. It takes what it wants."
-Little Sluice Memorial Weekend 2012 |
#306 (permalink) |
MASTER TECH
Member # 54844
you couldnt hit me from philly
![]() ![]() the only progress was finishing the track arm mounts - ill get some pics -
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html |
#308 (permalink) |
MASTER TECH
Member # 54844
well for the update vultures here - a few pics
the lower track arm mount - 1/4"rear - 1.75 .120 wall herw brace - the front is 3/16" - ![]() ![]() ![]() then the upper - had to fill the frame hole with some 1/4 and then the main mount is 1/4 - will have a bump stop made on the rear of the mount when all is said and done - - so will the other side ![]() ![]() here you can see the angles - close enough for me i have over 7.5" of up travel before the bumps hit ( from height now - will go down arounf 1.5" ) ![]() and a new TURNED AROUND pic ![]()
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy http://www.pirate4x4.com/forum/showthread.php?t=544813 |
#309 (permalink) |
MASTER TECH
Member # 54844
oh and you can see the soon to be "speed hole" marks in the front axle -
the rear will get some too - i hope my tax return is ok and i think im going to get some rear air shocks -
#310 (permalink) |
Member # 89796
i really like the upper track bar mount. overall its looking awsome man, keep it up
93 Bronco 351/e4od/1356, d60 sas, 10.25 rear, ARBs, 5.13s, 39.5" Iroks, 8 bolt H1s |
#311 (permalink) |
MASTER TECH
Member # 54844
no real progress - work was really slow and i had no hours - so i quit and got a new job - same shit diffrent locaton - so the cash is all but gone - all i have done is some diff covers - got them from trailerguy - they came off his buggy - he changed them and i got his trail tested covers - so - my truggy has been to the rubicon and the hammers - but it never left the shop -
i have some pics of the rear - i blasted it and welded the inner seams ( had some rtv on it ) heated and straightened the lower half ( he peeled back 1/2 plate )and had my buddy at the mach. shop make it flat - then tied it to my truss - ( missing the bolt and holes in the pics as i forgot my 5/8 bit ) will blast the front and weld the inners the same way - then tie it to the truss and make a ram mount
#312 (permalink) |
MASTER TECH
Member # 54844
rear diff
![]() ![]() ![]() the finger that ties the cover to the truss is .250 plate with a .188 cover - the tube is 1.5 x.375 dom ( 5/8 hole ) - but i dont have my drill and 5/8 bit to finish it -
#317 (permalink) |
MASTER TECH
Member # 54844
the finger ties the center section to the truss - i have seen 14 bolts break the plug welds and spin the center chunk - it helps tie the cover into the truss - i am going to weld the tubes too - just havent gotton that far -
i got the covers used from a friend ( read above / before the pics - i know its hard )
#318 (permalink) | |
89 Ranger, 2.9, 6" lift, 35" baja claws 92 Silverado, 6.2L, GM-3 Turbo at 10PSI |
#320 (permalink) |
MASTER TECH
Member # 54844
dose anyone read ? no - i make everything - started to blast the front - then got tired and thought i should come in and check my PMs
#321 (permalink) |
Member # 26394
I have spun mine and so have two of my good friends!
78 Bronco, 4" lift, 2" body lift,42" TSLs, KORE Beadlocks, 4.88 gears, 14 bolt with detroit, HP60 front welded, Psycho Fab doors, High Angle rear driveshaft, Warn HS9500 |
#322 (permalink) | |
Damn you chuckie...
![]() puuurrrrdyyyyy piiiicccctttuuuressss ![]() who needs to read?
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
#324 (permalink) |
MASTER TECH
Member # 54844
na - the coils are not going to be there forever - i want to have coilovers at all 4 corners - so i didnt want to cut the shit off when i get them - there is some 1/4 half circles under the spring plates though -
#325 (permalink) |
BSW
Member # 42436
I thought you said that you make EVERYTHING! but you didnt make the diff covers!
![]() lookin good man, hurry up, shit at this rate you will be done before me, at least I will have someone else to wheel with!
