Member # 82132
390 FE parts
Ok so I have a few questions for you ford guys.... The 390 I have now has the stupid ford electronic ignition with all the wires butchered up. What are my alternatives for distributors? Wouldnt it be easier to just go back to the old points style distributor since its going to be in the mud alot? Does anybody make an aftermarket HEI distributor for it besides Mallory or MSD??
Member # 47479
I used a Jacobs Electronics Omni Pack on my 390. It has worked well for quite some time, but it piggy backs off the OEM ignition system. If I had to do it all over again, I would use the Davis Unified Ignition distributor. It’s a complete stand alone, “Plug-n-Play” system. http://www.performancedistributors.com/forddui.htm That’s their web site for the Ford distributors.
[FONT="Comic Sans MS"]Every day is a good day when you wake up, it's the rest of your day that goes to crap![/FONT] |
Old Ford Guy
Member # 27645
The guys on the FE forum have done many dyno test and found the Duraspark is as good as any to 6,000-7,000rpms. Fix the wiring goobers and recurve your Duraspark, they've always been good to me. Make sure the ignition box is mounted solid, vibration kills these things.
Real trucks have the dimmer switch on the floor. |
Member # 47479
The only way you’re going to keep it CHEAP is to fix your factory wiring, and use OEM parts. Get a wiring schematic (Chiltons or Hayes manual) and replace any worn parts with stuff from any of the national chain parts stores.
Member # 82132
See my problem is that somebody put that ignition system on the truck.... it ORIGINALLY had the old points style from the factory. Thats why its going to be a mess to stick with that electronic ignition. Its too bad those D.U.I. setups are so pricey or else I would go that route.
Old Ford Guy
Member # 27645
Also cheap/fast if you don't want to keep the Duraspark is restore the fawkupd point dizzy and put a Pertronixs kit in it. I think they are like $60 on ebay.
Here ya go: http://cgi.ebay.com/ebaymotors/PERTR...spagenameZWDVW
#11 (permalink) | |
Old Ford Guy
Member # 27645
X2
