Intake manifold gasket question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-30-2007, 06:54 PM   #1 (permalink)
Member # 43613
Send a message via AIM to BigWhiteStroke
I have a bad intake manifold gasket on my 351w. That cork part that sits under the front of the intake has pushed itself out from under the intake, and a section of about 3 inches has ripped off. Could this be causing me to have a vacume leak? I know....a dumbazz question, but I am unsure of the answer..
BigWhiteStroke is offline   Reply With Quote Quick reply to this message
Old 01-31-2007, 07:10 AM   #2 (permalink)
Member # 79151
It should not cause a vacuum leak since that is not sealing the air passages. You should have a pretty good oil leak though when you run it hard.
MOSS2 is offline   Reply With Quote Quick reply to this message
Old 01-31-2007, 12:46 PM   #3 (permalink)
Member # 43613
Hmm, I don't have an oil leak, and I have around 60 psi of oil pressure...
Old 02-01-2007, 07:14 PM   #4 (permalink)
Member # 54844
- he means u will - there is no pressurised oil here - just splash - if its easy to geet to get some permitex in the cheeze wiz can and seal it back up ( make shure u clean it ) - did it a few times on my FE motors
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 02-02-2007, 08:58 AM   #5 (permalink)
Member # 43613
Yea i'll probably try that. Alot easier than pulling the intake for now. At least that will tell me if thats my problem or not.
Old 02-02-2007, 12:51 PM   #6 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
This is why you don't use the cork end gaskets. Just RTV. They suck
In vino veritas
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote Quick reply to this message
