Np205 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2007, 06:00 PM   #1 (permalink)
odin544's Avatar
Member # 29622
Np205
anyone have an exploded view of the np205 or have a link to it? ive searched with no helpful results
thanks
odin544 is offline   Reply With Quote
Old 02-02-2007, 07:34 PM   #2 (permalink)
mj
Member # 1919
like this
I got more if that aint good enough
mj is offline   Reply With Quote
Old 02-02-2007, 07:36 PM   #3 (permalink)
mj
Member # 1919
old one
Old 02-02-2007, 07:43 PM   #4 (permalink)
mj
Member # 1919
another
Old 02-02-2007, 07:44 PM   #5 (permalink)
mj
Member # 1919
cut away
Old 02-02-2007, 07:50 PM   #6 (permalink)
odin544's Avatar
Member # 29622
ok. well what im trying to figure out is how the speedo gear is indexed with the rear output shaft. on a chevy shaft the speedo gear slips over splines to keep it from spinning. on the 32 spline ford shaft i recieved to replace my chevy shaft there are no splines. the speedo gear spins freely on the shaft. does the yoke hold it by means of compression?
Old 02-03-2007, 04:58 PM   #7 (permalink)
76HighBoy's Avatar
Member # 47479
If my memory serves me correct, I believe there is a locking spring clip that holds the spedo gear in place. The spedo gear should have a key way in it that the spring clip sits in longitudinally. Then there should be a small hole in the output shaft where the spedo gear goes, that’s where a small tang in the spring clip locks in so that it doesn’t free spin. Once again, it’s been a few years since I’ve had my 205 open, so this is going off of memory.
[FONT="Comic Sans MS"]Every day is a good day when you wake up, it's the rest of your day that goes to crap![/FONT]
76HighBoy is offline   Reply With Quote
