pitman arm - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2007, 08:00 PM   #1 (permalink)
Newbie
Member # 66744
pitman arm
i just installed a dana 44 in my bronco 2 with leafs, and i used high steer. i also moved my axle forward 3". now i am having trouble with the drag link hiting the sterring rod under flex. i need a more flater and mabye longer pitman arm, were can i find one to fit? i also would NOT like to relocate the power steering box.
CherryRedB2 is offline   Reply With Quote
Old 02-12-2007, 08:18 PM   #2 (permalink)
Member # 86892
dont know for sure but you might want to look at a early 66-77 bronco stock pitman arm. there are flat and about 4-5 inches long. just an idea! keep us informed on what you find!
EBCRAWLIN is offline   Reply With Quote
Old 02-12-2007, 09:39 PM   #3 (permalink)
Newbie
Member # 66744
i figured out that waggys pitman armwould work best. 7in lon and 3/8 of drop. i all so found out that almost all american power string boxes are 36 spline
Old 02-14-2007, 02:57 PM   #4 (permalink)
Newbie
Member # 66744
this is the problem i am having
Old 02-14-2007, 05:13 PM   #5 (permalink)
Banned
Member # 48208
99-04 superduty's use flat pitman arms
f250crawler is offline   Reply With Quote
Old 02-14-2007, 05:38 PM   #6 (permalink)
Member # 42546
Ya but they had to differant spline counts
big specht is offline   Reply With Quote
Old 02-14-2007, 10:06 PM   #7 (permalink)
never fear
REDWAGON1985's Avatar
Member # 61115
90's f350 are petty flat...and have more metal incase you need to ream it.
REDWAGON1985 is offline   Reply With Quote
Old 02-14-2007, 10:38 PM   #8 (permalink)
Banned
Member # 48208
dunno then.
the 04 superduty pitman arm i have has the same spline as my 89 pitman arm.
but iam not sure if the b2 uses the same gearbox as the fsb,150, and 250's use from that same time frame
Old 02-15-2007, 04:07 PM   #9 (permalink)
Member # 66120
move steering box 3 in forward.
1ton70 is offline   Reply With Quote
Old 02-16-2007, 03:11 PM   #10 (permalink)
Member # 16438
I used a pitman arm from a 78 bronco on mine. Yes, the spline count was the same but it was way too small for the shaft on the B2. Had to file the splines by hand and file the bastard splines out. Took me about 2 hours of filing and test fitting. The pitman arm is a LOT flatter and not near as much drop, along with being around an inch longer.
AKBroncoII is offline   Reply With Quote
Old 02-16-2007, 03:12 PM   #11 (permalink)
Member # 85036
I just pulled a flat one a couple weeks ago from a stock bronco.
Blown349 is offline   Reply With Quote
Old 02-17-2007, 01:58 PM   #12 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
what year bronco? Unless it doesn't matter, but I'm needing one for a 80-96 F150/bronco. If you've got one to sell, let me know and I'll see what I can do.
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is offline   Reply With Quote
Old 02-17-2007, 02:20 PM   #13 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
I think I have a stock pitman arm from an 84 F150 that I lifted back when I was driving it in high school. I'll scrouge around and see what I can find.
Aces'n'8s is offline   Reply With Quote
Old 02-17-2007, 02:59 PM   #14 (permalink)
Rapey
animator's Avatar
Member # 13701
Cool. let me know if you can find it and want to sell it.
Old 02-17-2007, 03:04 PM   #15 (permalink)
Axes of E-ville
Aces'n'8s's Avatar
Member # 48097
Sure. I'll PM you when/if I find it.
