Member # 69442
Good 4x4 cam
I am trying to decide on a cam for my project I am doing. It's going to have an almost stock 302. Intake and headers are the main difference. Just trying to decide on what came to put in. What range of RPM etc. New to this whole cam thing so figured I would post a question here. The vehicle will be a daily driver but will also be used for some mild 4x4.
Member # 39369
I ran a Melling MTF-5 cam in my mostly stock 302. It's a great towing/RV/torque cam. It's the same grind many manufactures sell as a RV cam, FRP, Summit, Melling, Edelbrock.
Member # 69442
Thanks guys for the replies. It sends me in the right direction. I' ll maybe source up some sort of RV cam maybe and give it a whirl. If it doesnt work like I want I'll try something else. Will give me something to do on rainy days.
Member # 64817
For your mission profile, any cam marketed for RV or 4x4 application would work just fine. We could argue fine points all day, but for what you are using it for the subtle differences between the different offerings just won't matter. With that said, I've had good luck with the cheep Summit store brand cams. I've never used a name brand cam so I can't give a good opinion one way or the other.
Tronchaser
Member # 36490
I ran a cam I had INSKI grind to the specs of the old Ford 260. You couldn't stop the engine at idle, but it would fall on its face at 4500.
www.sharetrails.org |
Member # 83061
I guy told me once to, pick the cam you want then go to sizes smaller . and its good advise ,
Better to have one run off a little short than have one with to high of a rpm range. just my 2 cents |
IH/Rover Moderator
You haven't given us enough info to give you good advice!
Just look at the post count of all the noobs that seem to have a crystal ball and spew "tech" that is a perfect fit to your application! We need the following info: the weight of your rig Stick or auto diffs gear ratio tire size
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
