Moderhater
Member # 16980
GM saginaw pump in yer ferd
so my cheap truck is getting some steering action revamped.
the box is being rebuilt from WTOR, and getting ported for hydro assist. all in anticipation of the front spool, and soon to be mud drags that are going on up here. anywhoo, i need to put a GM Canned Ham p/s box on my ferd. anyone got some pics of brackets? i still need to buy the pump so i can get to it, but it never hurts to ask ![]() currently i have the p/s pump that looks like a cherry bomb, with the little steel dipstick.
Im your BMW huckleberry https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car! gun facts that will blow your mind: http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf |
Moderhater
Member # 16980
yea see i dont have that bracket. i have the one that is on the engine, but i dont have the bracket that bolts to the p/s pump. is it that easy?
Moderhater
Member # 16980
show me the way!!!
Member # 1919
cardone p#20-6244
http://www.cardone.com/English/Club/...ns/pt50-20.asp find a parts house that carries cardone and order it. it was pricey here |
77 ltd with a 400 and hydro boost. I had to move the bracket and modify it some so it would fit with the factory AC brackets which is my york compressor now.
408ci SEFI, 70mm throttle body, 90mm mass air, stang harness, tweecer R/T waiting on a home. |
Fawkin Fordhead
Find a Van with your engine, scam it's pump... Ford always has, and still does run Siagnaws on the vans.
Heck, even if it's not the same engine, the bracket bolted to the pump will probably bolt to your brackets.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
Member # 30098
van pump and bracket
[FONT=Arial]Feature Editor C4x4.com. Former owner of project This Old Scout. New owner of Project 'Blue Oval YJ', an 89 Wrangler with lots of potential! [url]http://www.c4x4.com/new_projects/yj/blue_oval_yj.html[/url] [/FONT] |
#12 (permalink) |
Member # 29565
I have the Saginaw unit on mine...Lincoln's w/ Hydroboost used the Saginaw pump and the A6 AC unit instead of the weak Ford PS pump and the York AC unit.
The reason that I have the A6 unit for OBA is because I wasn't willing to get rid of the Saginaw pump. At the time, I did not know of a way to have both the York AC unit for OBA and the Saginaw pump....and being able to steer was more important than airing up tires. BTW, the A6 OBA setup works great...zero complaints, and it is often used to air up 12 tires in a row at the end of a ride....mine and a couple moochers. Roy
1978 Big Ugly FORD F-350 460, C-6, NP 205, 4.10, 1410 DS Joints D60: Detroit, Dedenbear Knuckles, Yukon 4340 35 spline inners & outers, Longfield Superjoints, Drive Flanges Dana 70-U: Welded 4 Wheel Disc Brakes MM 12K Electric Winch Dual Batteries, A-6 OBA No Lift, 42" TSL's on 15x8's |
#13 (permalink) |
Member # 39734
I got my pump at Napa pat # 20-6244, I guess the same one as cardone. It was like $120. I bolts to the stock ford bracket. Mine is on a 351w and a buddy has it on his 302. It will move my 38.5's with the ARB on. Forgot to add that the price included the core charge. Also if going to a full size steering box the lines will match, you do not need the adapter.
Idiot Last edited by GWBronco; 03-01-2007 at 10:00 AM. |
#14 (permalink) |
It looks like it's an off-the-shelf unit from O-Reilly's.
http://www.oreillyauto.com/EW3/ByPar...ction=doSearch Give them your old pump for a core, and save $45
I consider myself a student of the game, it's just too bad I'm in special ed... |
#16 (permalink) |
Member # 48513
x2. I just did this, scored the bracket and sag pump for $28 from the pull-a-part. The rebuild kit for the sag pump was only another $16 from Advance Auto, and my existing power steering hose fit the sag pump just fine.
#18 (permalink) |
advance auto parts lists the pump online for a:
Vehicle: 1975 FORD E-250 ECONOLINE CLUB WAGON Engine: V8 5.8 Liter 2BBL http://www.partsamerica.com/ProductD...pe=251&PTSet=A 55.00 + 14.99 core charge..... you can get free shipping if order it online
Mud DriverI: 79 F150 built 400M, 35x14.5x15 boggers, 4" lift, 9"R, D44 F, NP435, NP203 : [url]http://www.cardomain.com/ride/2145548[/url] Mud DriverII: 77 F250 stock 400M, 36x12.5x16.5 TSL's, highboy, D60 R,D44F HD , NP435, np205 : [url]http://www.cardomain.com/ride/393604[/url] |
