Member # 9925
Bubba Hyde Build...
Starting from scratch, so this will take a while.
Bubba Hyde should be a somewhat unique design. As the name (based on the song) indicates, it's a dual personality rig. Unlike ScottFJ40 (oh, the sadness), ndeep, & I, it'll only have 2 personalities. Exterior is to be hardcore trail rig. Interior will be all day ride plush. While I love the hardcore buggies, my wife and 2 young sons will much prefer something that will keep out the rain, be comfortable, have some entertainment, etc. Here are the design elements. '79 F150 frame - highly modified. '76 F250 Crew Cab - highly modified. Unimog 404 axles. Ford 460 / C6 / 205. Tube rear with 3-link & coilovers. Tube front with shortened hood, 3-link, and coilovers. 90+ degree approach and departure angles. 42" Iroks.
---------- "All great change in America begins at the dinner table" ~ Ronald Reagan Last edited by loveshackle; 05-28-2007 at 04:22 PM. Reason: changed tire size... |
Member # 9925
Here is the original truck I started with. Has been in the family for years, and my sister and I have dented every panel. Had over 260k miles. 351M / T-18 / 205 with a HP D44 / 9" combo.
Ran it the last two years with no front fenders and 37" Swampers. But want a lot more. Body is now gone. Kept the VIN tag and the rolling chassis. Pic 3 is the '76 Crew Cab I picked up at Canyon Truck in Canon City, CO. Needs lots of work, but as I'm gonna change it all, it will work. Pic 4 is the stock rolling frame. Pic 5 is the pair of Mogs I bought on this board, out of Albuquerque.
---------- "All great change in America begins at the dinner table" ~ Ronald Reagan |
Member # 9925
Pulled the stock axles, which then received 5.13 gears with an OX in the front & Detroit in the rear. They'll get a new set of 35" Swampers and go under my '64 FJ40, including the radius arm front suspension.
First cut was taking the back 3 1/2' off the frame. The 37's in the pics were sold on this board to a guy in Durango, CO for his Jeep project. They made a full circle, as I bought them off this board out of SLC a while back.
Member # 9925
Sandblasted the frame, braced it, and cut out all the crossmembers except the welded in front drop crossmember, which I won't remove until the frame is mocked up above the axles.
Filled the 178 holes in the portion of the frame I am keeping (basically the length under the crew cab and 1' forward). The front body mounts are the center point of this build. Everything is aligned/measured from them. However, I wasn't happy with the way they extend below the frame and are riveted on, so I cut them off, scalloped them, welded the lower bushing plate inside the mount, 'boxed' the mount with 1/8" steel, and welded them back on the frame in their original locations. Installed 1" x 1" square tube inside the upper driver frame rail. This is for routing the locker cable and electrical to the rear of the truck. This will be joined by 1 1/2" pipe inside the bottom of each frame rail for routing coolant to & from the rear mounted radiator (necessary due to the bobbed front end). I'll then box the frame rails with 1/8", recessed 3/4" to allow for further wiring / brake lines / rear heater pipe routing while not being readily visible or subject to damage.
I really like what your doing, but I think you'll regret using the 404's under that build. I'd use 406s as the minimum, with u1300's as preferrable. But then, I do tend to overbuild.
[QUOTE=94stepsideford;7266691]Seth is scarier than you though. He looks like he would kill and eat a baby with his bare hands.[/QUOTE] '73 F250, 533 on N2o, 35spln chromo Superior/CTM D60/D70, twinsticked 205, hydro-assist, f&r lockers, HAD drivelines, 46" Titan R1s. Vid: [url]http://youtu.be/KaL-IsCWrrI[/url] [url]http://youtu.be/l9cuRoEfCn0[/url] |
Member # 9925
I hear ya, Pro, but I'm pretty light on the pedal...and I'm not afraid to buy the CNC portal boxes, if I start breakin' em. Don't think that thought hasn't crossed my mind, tho.
Thanks for the comments. Cut & fit all the boxing plates today & a piece of 7" channel (1/4") to make my rear crossmember, tying the two ends of the frame together & a mounting point for my upper links. Lots of boxing to come. Making boxing plates in the center of the chassis (at rear footwell) & at the rear that will be removable. Also, passing the coolant pipes and wiring tube thru the rear crossmember.
#9 (permalink) | |
Member # 9925
2 screens and a PS3, actually, Pro.
Z-dude. I went with the mogs because 1) portal was important. Clearance & big rubber without rig height is of the upmost importance to me. 2) I got, I think, a great deal. 3) My personal thought is that Rocks are overkill for what I need, and everybody and their mother is doing 'em. Don't get me wrong, they work, and are bad ass, but I find the Mogs more unique and interesting.
#12 (permalink) | |
Member # 37340
#17 (permalink) |
Well Done Man!
Filling the swiss cheese on the frame will make it look clean! I also dig that body mount.
I am not sure about running the wire in the tube, I guess I change mine to much where I can string a new loom in sec's where fishing wire sucks.
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
#18 (permalink) |
Member # 85265
sweet build exactly like mine but, i'm using rockwells and a 351m. What wheelbase are you shootin for and where is your cab going to be(how much space behind it of frame will be left) i ask because if i made a fram i'de like to have the back of the cab like 6" from the back of the fram but i'm worried about visibility. also what do you mean be tubed front and rear like a tube bed and fenders or a back half job?
the beatings will continue until morale improves. |
#19 (permalink) |
Member # 9925
Shooting for <133" (edit 6/9/07: not gonna happen, especially with 49's. Wheelbase will be ~145") wheelbase. Frame stops about 2" beyond back of cab. Will be tube beyond there, with a fuel cell, batts, radiator, and something special frenched into the front of the fuel cell so you can't tell it exists.
Will have removable outer skins of 'stock' fenders that fasten to the tube, albeit shortened significantly. Center of front axle is now aligned with the center of the stock panhard rod mount on the frame. Rear tires will clear back of cab by 3" in full compression. Modified frame will extend from front of grill (moved back 6-8" from stock) to the rear of the cab, with a C-notch at the front axle. Bent 1 5/8" OD pipe for the radiator plumbing, 1 on each side, so that they are flush inside the bottom of the frame rails. Cutting mounting tabs & the 'turnouts' for the front ends now. Boxing plates are cut and fit, along with removable center sections. Boxing frame ~3/4" inside the edge of the frame, so any additional wiring, etc, will have a nice protected place to hang out. The electical tube and coolant pipes will pass thru the rear crossmember (boxed and gusseted 7" channel). With easy access to both ends of the electrical tube, and a wiring plan I've been laying out for 2 years, I'm not concerned about the difficulty of 'redoing' wiring there.
---------- "All great change in America begins at the dinner table" ~ Ronald Reagan Last edited by loveshackle; 06-09-2007 at 04:50 PM. |
#21 (permalink) |
Member # 9925
Here's some shots of the coolant pipes going from engine back to the rear-mounted radiator location. Schedule 80 pipe. Still long on the rear...will be shortened & upturned later. Mocked in place. Primed back of pipe and inside of frame rails where pipe sits. Pulled out & welded tabs & turnouts in place. Ran beads around the finished end (engine bay side) for hose mounting. Remounted and welded into frame.
Boxing & rear crossmember are next.
---------- "All great change in America begins at the dinner table" ~ Ronald Reagan Last edited by loveshackle; 03-24-2007 at 07:14 PM. |
#23 (permalink) | |
Addicted to Gear Oil
Member # 56050
![]() Not a ford guy, but I like this one.... Just watch him met-a-morphi-size from Barney Jekyll into Bubba Hyde!
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
#24 (permalink) |
Just remember to leave ample flex points on the coolant pipe
