Member # 16438
threading shock body?
Anyone know a machine shop that will do this for me? I want to make a set of coilovers out of a set of King remote shocks. I've called king about getting new bodies but it was going to be near the cost of a new set of shocks. Any help would be much appreciated.
Member # 44108
id like this info also...i have a set of 2.5" 16s and 18s that would be perfect....but ive just been trying to sell them since they arent setup for coils.
[center][SIZE="4"][url]Shop.FarmboyFabrications.com[/url][/SIZE] [B][SIZE="6"] [COLOR="DarkRed"]239.337.LIFT[/COLOR][/SIZE][/B] [SIZE="4"] [COLOR="Silver"]One Up Offroad[/COLOR][COLOR="DarkRed"] Rize Industries [/COLOR][COLOR="Silver"]Icon Vehicle Dynamics [/COLOR][COLOR="Yellow"]RCD[/COLOR] [COLOR="Silver"]Full-Traction[/COLOR] [COLOR="darkred"]Rubicon Express [/COLOR][COLOR="Navy"]KING[/COLOR][COLOR="DarkRed"] Sway-a-Way[/COLOR][COLOR="Navy"] FOX[/COLOR] [COLOR="Silver"]Dynatrac[/COLOR] [COLOR="Indigo"]Yukon Gear[/COLOR] [COLOR="DarkRed"]ARB [/COLOR][COLOR="Silver"]Detroit[/COLOR] [/SIZE] Including the largest selection of tires and wheels that you will find. Don't see what you are looking for? Give us a call.[/center] |
Member # 16438
Are yours kings? I don't see why they can't be turned. I looked at a set of 2.5" kings at a friends house today which gave me the idea. As far as I could tell, the bodies were identical. He also had a set of 2.5" SAW's that had the lower portion of the shock turned down so you could put the adjusters in from the shaft side.
Member # 44108
Fox's...i dont have anything to compare them to
Member # 85265
i think if this worked then somone would have thought about it and everyone would know that you could do it. But if you can take shocks apart and have a coilover to compare it to and it looks the same then knock your self out.
the beatings will continue until morale improves. |
Member # 16438
Oh, I know it CAN be done. Just not sure why no one has done it before. Seems like it would save some money. Especially since I already have the shocks and got them for free. Even after rebuilding them and having them threaded I'll still have less into them than even 1 coilover shock.
Member # 85265
maybe the bodys thickness is different like a coilovers has to stand up to the wieght of the vehicle and a shock just has to "dampen the movement". I was a northern tool yesterday and say some fine thread 2" dyes that may work some way.
Member # 74498
as long as the thickness of the shock body has enough meat to cut the thread i dont see wy a shop wouldnt do it for you. i cant remember the thread depth for a 2" 12tpi thread right now but as long as you have more than 1/8" of metal per side they should be able to thread them
Chris Last edited by The_Undecided; 03-20-2007 at 08:29 PM. |
#13 (permalink) |
Member # 16438
That is also possible. Maybe to make the outter diameter 2.5"s for 3" ID springs? The only probably I could see is trying to fasten it to the shock body itself. I'm definitely open to suggestions.
#15 (permalink) |
Member # 16438
I tried that already. Was told it was going to be near the price of a new set of coilovers.
I did some searching. Found out, the 2.5" kings are .127" wall tubing. I just measured the thickness of the 2" kings I have and they are also .127" wall. Looks like I should have plenty of material. If this doesn't work, I'm just going to make my own shock body. thought others might like this for reference. I found it when looking for shock body diameters and thickness. A little coilover internals comparison. http://www.offroad-engineering.com/foxvsking.html Last edited by AKBroncoII; 03-31-2007 at 12:21 PM. |
#16 (permalink) |
Member # 44108
maybe we would get more help in general discussion?
#17 (permalink) |
Member # 16438
Is there any way to move this over to general discussion? I know that sway away sells there shock bodies separate. I called King and they didn't seem too happy to sell me one of there bodies separately. I was going to set up these kings to use the sway away hardware kit since they are more readily available.
