Dana 70 disk brake conversion? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2007, 09:07 PM   #1 (permalink)
monsterburban's Avatar
Member # 86207
does anybody know of a factory built disk brake rotor that will fit onto the hub of a dual wheel dana 70 rear axle. i am building a project mud bogger and i cant afford the 650 dollars for a premade conversion kit. i really would like to run disks. if anybody has any info or advice please help. i would really like to find a rotor that i dont need to machine to fit over the hub correctly. thanks for your help.
monsterburban is offline   Reply With Quote Quick reply to this message
Old 03-19-2007, 09:46 PM   #2 (permalink)
Member # 9468
Send a message via ICQ to masterbeavis Send a message via AIM to masterbeavis Send a message via MSN to masterbeavis Send a message via Yahoo to masterbeavis
machine the hub to fit the rotor. this way if you roach the rotor, you wont have to pay to have the new ones machined again
masterbeavis is offline   Reply With Quote Quick reply to this message
Old 03-20-2007, 05:01 AM   #3 (permalink)
Member # 47246
Send a message via AIM to NHRedneck
in the axles tire n wheel vendor area, theres a vendor that has rotors and brackets for 140$..... check em out they look pretty sweet and have the larger hole in the center to fit the hub.... he says they are for SRW though
Mud DriverI: 79 F150 built 400M, 35x14.5x15 boggers, 4" lift, 9"R, D44 F, NP435, NP203 :
Mud DriverII: 77 F250 stock 400M, 36x12.5x16.5 TSL's, highboy, D60 R,D44F HD , NP435, np205 :
NHRedneck is offline   Reply With Quote Quick reply to this message
Old 03-20-2007, 07:01 AM   #4 (permalink)
NPKenny's Avatar
Member # 71169
GreatLakeOffroad in the vendor section makes the brackets for the disk brake conversions. If the DRW is the same Dana 70 as the SRW 70, the front rotors and calipers from a K20 should work. I am in the process of a disk brake conversion on a SRW 70 now.
Again, GreatLakeOffroad has done a good bit of R&D on these conversions. He would know the answers for you.
NPK
NPKenny is offline   Reply With Quote Quick reply to this message
Old 06-21-2010, 11:07 AM   #5 (permalink)
badlarry's Avatar
Member # 118892
UP, UP, UP... I'm looking for some more info on this too...Anyone?
badlarry is offline   Reply With Quote Quick reply to this message
Old 06-21-2010, 09:31 PM   #6 (permalink)
Member # 99527
ok so ill help you do what should be a easy task of "searching" yes it might take a few minutes to find what you need but google is not as hard as some make it sound.
just because of your name im taking a guess
http://www.ruffstuffspecialties.com/...lly-p-219.html
or try these
http://www.ruffstuffspecialties.com/...xle-p-176.html
or just cough up the money
http://www.blackbirdscustomtrucks.com/index8.html
then you got a choice
get a 3/4 ton ford rotor open the center up
get a 3/4 ton chevy rotor open center up
mill the hub to fit one of the above
popeye123 is offline   Reply With Quote Quick reply to this message
Old 06-21-2010, 10:25 PM   #7 (permalink)
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
What style of brakes are on this D70? Inboard, stud retained, or outboard, slip ons?
I personally like using the outboard setup and an E350 rear rotor(pretty much anything 96+ for an app) as it stays slip on and is cheap.
96 F350 XL CC PSD/5 speed 4x4... Family hauler in the making
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk...
82F100SWB is offline   Reply With Quote Quick reply to this message
Old 06-21-2010, 11:39 PM   #8 (permalink)
Member # 26115
A bit off topic guys. (dont want to start a new thread)
Just did a rear disc swap on my rear D70 (chev 3/4 ton calipers/rotors/ruffstuff brackets) & using a 78' F250 master cylinder. (factory suzuki xl-7 booster-much bigger than a sammy etc..)
Having major issues, system bleeds great, master was bench bled etc....
Pedal is great but:
When you start the truck pedal hits the floor.
Any thoughts? Should we look into a corvette or similar master meant for dual discs??
Or am I just not thinking & missing something. Spent about an hour bleeding tonight Could try bleeding again...... UGH
2002 Suzuki XL-7 37's-1Tons
Project XL-XL7
zuki4x4chick is offline   Reply With Quote Quick reply to this message
Old 06-22-2010, 06:03 AM   #9 (permalink)
KyleQ's Avatar
Member # 83837
I went the Rough Stuff route and it was simple -
Weld on caliper mount-
Light machining to get rotor to fit-
Spend way too much money figuring out what studs fit and pay too much for them at Napa because you needed them right away
Complete -
Clears a 15" wheel when you threaten it with a flap disk-
Even after spending too much money on Napa studs (much cheaper online, figure out what fits and then just order it) I had disk brakes on my D70 for ~$300.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60, Powr-Lok 70U - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 43" TSL SX on H1 Beadlocks
KyleQ is offline   Reply With Quote Quick reply to this message
Old 06-23-2010, 07:34 AM   #10 (permalink)
Member # 71891
the ruff stuff bolt on mounts are awsome. and he'll just tell you what disks you need. no more withholding info bullshit some of the others do.
95 ford bronco, 351W - one tons, 38's, lockers, no discernible driving ability
93 F250, 7.3T, ZF5
jam0o0 is offline   Reply With Quote Quick reply to this message
Old 03-09-2015, 05:11 PM   #11 (permalink)
Member # 560770
KyleQ just out of curiosity what stud did you find to work if you remember, I'm in the stage of trying countless wheel studs and it's getting old quidk lol! Any help appreciated!
CooperTucker is offline   Reply With Quote Quick reply to this message
Old 03-09-2015, 08:20 PM   #12 (permalink)
Member # 156216
I refuse to answer this question on the grounds that you did not Google first.
Buggies are boring. Jeeps are generic. Full size are more fun. Because size matters.
hasteranger is offline   Reply With Quote Quick reply to this message
Old 03-09-2015, 08:28 PM   #13 (permalink)
69DieselLover's Avatar
Member # 210244
Didn't some 3/4 ton Dodges come with Dana 70's and disk brakes from the factory?
Should be able to get all the parts needed at the J/Y.
Probably as a set, rotors, brackets, calipers, and studs. Maybe even with a park brake...
Humboldt Hillbilly
My Diesel Sport Trac Build
69DieselLover is offline   Reply With Quote Quick reply to this message
Old 03-09-2015, 08:31 PM   #14 (permalink)
rabbiporkchop's Avatar
Member # 181404
Here is a creative option
http://www.fordmann.com/F250.Dana_70U.htm
95 solid axle Tahoe with LM7 swap
rabbiporkchop is offline   Reply With Quote Quick reply to this message
Old 03-22-2015, 01:33 AM   #15 (permalink)
7.62FMJ's Avatar
Member # 66780
I did it. Used Ruff Stuff's brackets, chebby calipers, and E350 rotors. For studs, I went to a commercial Auto supply house and dug through their bins to find one that would match. I took the old studs with me to compare. New ones needed to be longer, with a longer knurled section.
Found some that worked pretty good....but went in just a little too easy for my liking....so I tacked each one in
I only had $300 in it....complete disc conversion, new wheel bearings & seals, studs, paint, and gear oil.
A
Piss!
7.62FMJ is offline   Reply With Quote Quick reply to this message
Old 03-26-2015, 05:57 AM   #16 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
I sell a complete kit for $300 shipped
Dana 60 or 14 bolt disk brake kits $315 shipped -->
Dana 70 kits $300 -->
. . Sterling 10.25 kits $390 -->
Dana 60 front 3/4 ton kits $295-->
GubNi is offline   Reply With Quote Quick reply to this message
Old 03-27-2015, 02:47 PM   #17 (permalink)
Member # 4243
Originally Posted by rabbiporkchop View Post
I can confirm this new flange style/size is used on 01-02 Dodge D80 SRW, and E350 D70u DRW (same vintage). Interestingly, the Dodge rotor slips over the hub, whereas the Ford DRW rotor is mounted inboard on a 8x5.71" pattern.
Dodge cobbler... junkyard style (1stgen cummins theme)
u2slow is offline   Reply With Quote Quick reply to this message
Old 05-14-2015, 12:37 PM   #18 (permalink)
Member # 181404
I would still like to figure out a way to put my calipers on a Dana 70 so I could have my emergency brake like on my D60
Old 05-14-2015, 01:00 PM   #19 (permalink)
Member # 4243
http://www.pirate4x4.com/forum/inter...n-fat-ass.html
Fast forward to post #44 for good stuff
Old 05-14-2015, 01:05 PM   #20 (permalink)
Member # 181404
Awesome. I'll check it out
