Mustang with a tapping vavle! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2007, 11:01 PM   #1 (permalink)
Member # 81169
Send a message via AIM to 94toyota4x4
Thumbs down Mustang with a tapping vavle!
Ok, I have this 97 ford mustang cobra, It has a bad valve tap, and I was told that all it needs is adjusting, what I dont know is what to excatly adjsut, Im guessing valve height, and what to adjust it to, its getting pretty bad so if you could help me out that would be great, ford 282ci or 4.6L 32v engine.
94toyota4x4 is offline   Reply With Quote
Old 04-25-2007, 11:15 PM   #2 (permalink)
brandon916's Avatar
Member # 28438
Send a message via AIM to brandon916 Send a message via Yahoo to brandon916
run it low on oil? i dont know if the valves are ajustable.
brandon916 is offline   Reply With Quote
Old 04-26-2007, 12:27 PM   #3 (permalink)
MASTER TECH
f250rollinon37s's Avatar
Member # 54844
valves are not adj on the 4.6 - the 16 / 32 valve - may be a dead lifter -
BSW Racing, Calrocs Super mods 12 & ?
Driver: Aaron Whitehead - Driver: Joe Hutchins
Spotter: Adam Kovarik - Spotter: Dustin Knight
Crew Cheif: me fuckers
build up of the truggy
/forum/ford/544813-update-pics.html
f250rollinon37s is offline   Reply With Quote
Old 04-26-2007, 06:11 PM   #4 (permalink)
Member # 81169
well I know I have to get under the valve cover to see whats up, how can I tell if the lifter is dead, and theres nothing to adjsut the valves at all, not even anything dealing with valves, and oil level is full, o and the car lost quite a bit of performance when this started to happen.
Old 04-26-2007, 10:14 PM   #5 (permalink)
brandon916's Avatar
Member # 28438
check the plugs, i had a 03 gt that was pro charged and the same symptoms happened, it has a slight miss and was tapping. i pulled the plugs and they were smashed. the piston came apart. maybe the case if a miss is present
Old 04-26-2007, 11:09 PM   #6 (permalink)
Member # 81169
I already checked it plugs are fine, Im sure its a valve problem.
Old 04-26-2007, 11:50 PM   #7 (permalink)
Fordman500's Avatar
Member # 56456
I know 4.6s are notorious for that sound. My 99 cobra makes the same noise but not too bad. I dont know the fix, but I do have a great idea.. Why not try a mustang forum.
74 f100, 4bt, 3link hp 60/14 bolt, welded f/r np435/205
Fordman500 is offline   Reply With Quote
Old 04-27-2007, 04:05 PM   #8 (permalink)
Member # 81169
thing is I'm really not a mustang fan just trying to help my mom out with her car, the sound is real bad nothing normal at all, Ill try some mustang forums. Thanks
