Member # 62169
3:1 gears for a Ford 205
Low Max doesn't offer 3:1 gearing for the Ford NP205. From what I understand, no one offers them for the driver drop NP205. Anyone on here have a Ford 205 with 3:1 gears? Or know of where to get some?
'86 Wagoneer, 1 tons, cage, Stak 3 speed, 42's '10 F-350, Crew Cab, 4x4, 6.4L, 6 speed, 37's |
#2 (permalink) | |
In the garage
Member # 41068
Tow rig build: 1997 F350, Powerstroke, 4wd conversion Crawler build: 1990 Ford Ranger Truggy Daily driver build: 1965 Chevy |
Member # 25927
A doubler gives you 4 to 1 and with the trails around here that can be too low. A 3 to 1 would be perfect.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here Dana 60 front 3/4 ton kits $350--> click here |
Member # 85036
Eat linen, drink ink, shit cash, and get a Atlas II, Doubler, Klune V or Black Box!
Da "Carcass" Built by Swat. [url]http://www.supermotors.net/vehicles/registry/3612[/url] |
Member # 85265
alright so what year truck should i look for to get the t-case since I'll most likely hit the yard this weekend
the beatings will continue until morale improves. |
#12 (permalink) |
Member # 63840
80's and 90's should all have mag. chain drive bw case's i dont know off the top of my head what year they switched from 1345 to 1356. i cant say if one is stronger than the other. try to get one out of a bronco with a fixed yoke, but check the trucks to because i have heard of them having them to, but i have never seen one.
#13 (permalink) |
In the garage
Member # 41068
My 1345 came out of an 1984 F250 4x4, 460/c6/BW1345. There is a tag on the back of the case that will show the number. If you want I have Ford NP208 that has similiar gearing and fixed yokes. I am in the Reno area and price would be a case of Olympia beer!
#16 (permalink) |
Damn you chuckie...
yeah the only problem is the 1300 BWs are all chain drive... mines a 1356 and its worn to f***. only had one problem since the day i got it. other than a lil noise the BWs work.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
#17 (permalink) | ||
Member # 62169
I'm not getting any more aluminum cases or chain drives. Been there, done that...I need the beef. Quote:
'86 Wagoneer, 1 tons, cage, Stak 3 speed, 42's '10 F-350, Crew Cab, 4x4, 6.4L, 6 speed, 37's Last edited by Slick Willie; 04-29-2007 at 09:53 PM. |
#19 (permalink) | |
Member # 62169
I've never heard of 3:1 gears for a 203 either, so I'm trying to get more info if there is such a thing. The black box would marginally be close to the same gearing and work, but it's $1600 by itself compared to ~ $1k for piecing together a 3:1 205. If I have no luck here, I'll just pony up and get the 3 speed Stak box and bolt it up. I'm only considering the 203/205 because there's one for sale for cheap close to me.
'86 Wagoneer, 1 tons, cage, Stak 3 speed, 42's '10 F-350, Crew Cab, 4x4, 6.4L, 6 speed, 37's Last edited by Slick Willie; 04-30-2007 at 11:43 AM. |
#20 (permalink) |
Member # 17313
I've had good luck with my 1356/205 doubler. gives me the option of 2;1, 2.69:1, or 5.4: 1
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
#21 (permalink) |
Member # 42205
The 3 to 1 gears for my 203 were done by wagoner machine. It is a $1000 dollar mod and they cut a portion of the bottom of the 203 out to make the new gear fit. Wagoner machine may now be called Sumner machine but I am not sure of that.
#24 (permalink) |
Member # 16561
4 seat FJ40 buggy. Alum 5.3 - Th400 - Atlas 4 speed - 60/14 - 42" stickies...etc...[url]http://www.pirate4x4.com/forum/showthread.php?t=660786[/url] Gone but not forgotten: 81 toyota truggy - LT1 - Th400+203+atlas3.0 - 60 / 14 - 42s. [url]http://www.pirate4x4.com/forum/showthread.php?t=520948[/url]. |
#25 (permalink) |
Member # 40162
I know you stated you dont want the aluminum/chain drive case option, but if you are basing that decision on the weakness of the 208, you might reconsider. I was breaking 208's pretty regularly in my mud racing buggy untill I switched to the BW1345- wider chain, stronger case and lower low range (208-2.61 vs 1345-2.74) To my knowledge, the BW1356 is also a stronger case than the 208 but seems to have a reputation for loosing the oil pump, and if not caught quickly enough, well, you know. I have also been using a 1345 in my trail rig for over a year now with no issues- broken a rear 70 shaft, bent my front and rear suspension "links" and even torqued/bounced/ broke my front suspension completely off last weekend and the t-case is still holding up it's share.
"Time you shut your cake-hole, YOKO!!!" |
