So i kno a guy who has a 400 that he will give to me what transmissions will bolt up to this that are either a 4 or 5 speed and what transfer case will bolt up to a t-56 or is that just a 2wd transmission thank
Huh? The first thread is asking about 4 and 5 speeds. The ones listed are all manual transmissions.
As far as automatics go, there are a few options to choose from. The common choices would be a c6 or e4od but there are bellhousings to put a c4 behind one. The big problem with the c4 is that there is a lack of 4x4 output shaft and tail housing options unless you don't mind spending $500 or so for adapters. I don't think that the AOD was ever an option, but someone else can chime in if I'm mistaken on that.
4wdzr2, you should really do some searching. The answers to your questions are around and have been covered.
