Anybody ever had the oil idiot light stay on every time you start the engine. It stays lit up for about 5 seconds. i don't rememeber this haappening before. 03 E350 15' box van 7.3 with 70k . The dealer replaced the high volume oil pump under warranty( 100.00 out of my pocket) but it the same problem. Any ideas ? The oil pressure guage moves when the engine starts, like it works normally. I even changed the oil and filter just make sure that was not the problem.
thanks
Remove the sending unit and put a manual gauge on it. If the sender checks out it's either the low pressure pump or internal issues like excessive bearing clearances.
The oil pressure gauges on ALL 7.3's and 6.0's are mis-leading. They are not actual pressure gauges but just an on/off switch. If you have 5 psi. or more oil pressure... it reads half gauge. If it is 4 psi. OR LESS... it reads zero. The sender also reads off the low pressure pump (as stated above), so the HP pump shouldn't have been bothered unless you had other driveability concerns.
