I need to remove the differential in my 8.8 to replace the tone ring and reinstall, and it shouldn't need any shim readjustment since Im not regearing.
(After I remove the c-clips and slide the axleshafts out)
So I apply the yellow paste to make sure I have a good contact pattern, if so , then remove main bolt caps, and punch to indicate position for reinstall.
So whats the best way to remove the differential without disturbing the shims?
(1996 Ford Bronco with open rear 8.8)
