Member # 9799
need help!! Np435 questions
I did a search and didn't find the info that I wanted so I am going to try my luck with a thread. I am going to a pick-n-pull tomorrow and I am going to try to find a np435. I was wondering, what truck do I look to find it out of(4wd or 2wd), how do I check it to see if it is decent, will it adapt to my bellhousing(302), and if I find a six cylinder with a np435 will that work?
Thanks a lot for the info, anything helps!!! Lure
85 toy w/pick n pull bucket seats |
Member # 2790
Personally I would get the 4wd version since you are putting it in a 4wd.. Other than the tail housings the 435'sare the same.. If you find a 435 behind a 300 six cylinder you can use the bellhousing to bolt to your 302 if you dont already have one..
Russ hy_desert_4wheeler 46 Dodge WC15--67 M715--85 Jeep CJ10A--06 Dodge Ram2500Quad cab Cummins--94 Suburban--06 Ridgeline- |
Member # 6848
If you get the 4wd, get the adapter and xfer case as well. Otherwise I think you want the 2wd version. Go to http://www.classicbroncos.com and then the links section and go to the NP435 links. They will tell you what to look for.
The bellhousing is standard and will bolt up to your 302 housing. Make sure you get one with the shifter!
71 1-ton EB BITD 7200 |
Member # 595
If it is for your early Bronco then use one from a 67-83 Ford truck F100-350 small block, 28 spline output shaft with square tail housing bolt pattern. They also come bolted up to 360 and 390 engines. If you find one in a four wheel drive, it's best to use the ones that are bolted directly to the transfer case; they usually have the correct output shaft.
HTH
[COLOR="Red"]star[/COLOR] |
Member # 7064
Well, did ya get one? I saw a couple of guys wrestleing with a tranny in a Ford truck in Rocklin, was that you?
The gene pool could use a little chlorine. [url=http://rocknroll4x4.com/]Rock N Roll 4X4 Club[/url] |
Member # 9799
yup that was me!! The only problem was, I couldn't get the damn thing out. I could have but I just didn't have enough time. We had to be at my brothers at 4 o'clock to go to the con. Anywayz, I went back today to get it and sure enough someone snatched it. We put all the work into taking it out, just to leave it there. Oh well, there will be another
Member # 7064
You should have dropped that bell housing. Oh well, it wasn't ment to be. I didn't find anything there. I was not impressed at all.
#12 (permalink) |
Member # 9799
I should have dropped that bell housing but oh, I figure that it just wasn't meant to be and there will be another
(hopefully)Thanks for the tip Rogue Bronco, I will use a magnet next time
