I have a 70 f 150 and my buddy has a 71 f150. We both have the same problem we need a hub assembly. There both open knukle. The hub assembly slids over the axle tube and the ball joints go in the top and bottom. I have never seen this set up before. It is about 6 1/4 inches from top to bottom inside to inside on the hub assembly. I have a 78 f150 and its totally diferent it it bolts from the top of the axle tub knukle and the hub go's under it and on the bottom its the same. Well I am woundering were i can find these wierd hub assemblys at. Is there a company that makes these.
