Here is the scenerio... I have a 95' F350 Im using the engine (460)/trans (E40d)/transfer case (BW1356) to put in my 67' truck. But, the gas tank on the 95' is to wide since the earlier truck had the narrow frame, Im thinking 34" wide. Now I want the tank under the bed so thinking about putting a bronco 33 gallon tank back there using the skid plate, sending unit, pump etc.. will this work for the 460 setup? Possible problems, it might sit up to high and hit the truck bed so the upper straps wont work, therefore the skid plate might not work? Also, will the pump, sending unit work with the same connector or? Called a couple places and they seem to think the pump in the bronco is the same as my truck, just sending unit difference? Any thoughts?
Todd
Todd
