1993 Ford E150 5.0 trouble getting fuel
I have a 1993 Ford E150 5.0 with fuel problems. I changed out the fuel relay under the hood. I took out and put back in several fuses from the fuse box under the dash. After I did that the van started. I turned it off and it would not start again. I cannot hear the electric fuel pumpin the gas tank turning on when I turn the ignition on. What could cause this problem other than the fuel pump itself ?
Thanks
Tim
Thanks
Tim
