#1 (permalink) | |
83 bronco, auto to manual swap.
Anyone ripped the c6 out and dropped a 435 in?
is the firewall already prepped for a clutch pedal? basically a bolt in? any other snags other than driveline lengths?
☠ Quote:
Member # 39287
I did it with a no hydro clutch in my 84. he only hole I had to cut was for the clutch rod to go through the floor. Same x member, either cut a hole for the shifter or get a new trans tunnel cover from the junkyard. The pedals bolt right up. If the 83 had the option for the hydro clutch, the brake booster brace/ plate part of the firewall will have the approriate holes in it. You will need to drill out the firewall under it.
It was a simple swap, it took longer to get done due to the amount of beer flowing. |
Well Done Man!
On my friends 91, Everything was a bolt on.
Get got a new tunnel cover with the shifter hole already cut. The pedal brackets are a bolt on as well.
Mark 71 Bronco. 42's and bolt on goats. 47' CJ2a, 302, C4, 33's. 2012, year of the flat fender. |
Member # 16680
different years I konw, but on my 94 that never came with a stick and 351, mine was pretty much a bolt in. i used a zf (hydraulic clutch) but all the hose mounts were there, as well as a cover plate where the MC should be. I used my orig tunnel cover, and just plas'd a whole out.
94 Mall Rated Bronco-R.I.P. 1961 Scout 80 stretched and linked wt4x4.com PM me for CPR/First Aid Instruction for you club |
Fawkin Fordhead
On an 83, the firewall should be stamped where you need to drill beside the brake booster. My 82 was, my 81 wasn't.
![]() If you do a linkage clutch, you may have the hole already there, and just capped: ![]() I snagged that plug out of another 82(mine was linkage clutch, swapped to hydro with the 460 chassis,) so, you may already have the hole in place.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
