Total build time from dragging the chassis into the garage to taking it to a trial trail was 3 months and 3 days.
Specs
Chassis - built by Motorcity Machines.
Powertrain
Motor - Supercharged Ford 3.8L, bored 30 over, ported Eaton SC, ceramic coated pistons, 10% OD pulley (~14 PSI), cam, FMIC, etc
Trans - Ford C4, 2000 stall Torque Converter, Art Carr rev man VB with comp braking
T-case - Ford Dana 20, AA 32 spline output assembly, custom cable twin stick, KOZ custom clocking ring
Driveshafts - built by Joint Clutch and Gear, 1410s rear, 1330s front
Front Axle - 1989 Ford D60, KOZ highsteer arms, lincoln locked, GLO front diff cover
Rear axle - 1989 Ford Sterling 10.25, lincoln locked
Suspension
Links - Triangulated 4 link front and rear, QA1 heims, 7/8 x 7/8, 1-3/4" x 3/8" lowers, 1-1/2" x 1/4" uppers, weld in bungs.
Shocks - Fox 14"x2" fronts, 12"x2" rear
Steering - Full Hydro, Danfoss orbital, TSC single end ram, 1-1/2" x 1/4" tie rod, 3/4 x 3/4 heims.
Tires and Rims - H1 rims with mag runflats on custom cut 39.5" boggers
Misc - 108" WB, 82" outside tire to outside tire, 20" belly, B&M sport shifter (no reverse lockout), kirkley seats, summit "2 pipe" muffler, MSD external fuel pump, Optima red top,
and for the pics.....
used bare chassis
driving 3 months later
Specs
Powertrain
Suspension
used bare chassis
