which tranfer case can i use behind my m5od transmissing 2wd to make it 4x4 after taking the tail housing off can i do that and what t case any info would help in my build up of a 92 2.3 2wd into 2.3 4x4 30 front 4.10 35 rear 4.10 and 33 inch tires full cage i just cant seem to find a good t case will a np208 work thanks
You cant just pull the tailhousing off and slap a t-case on there. You need to swap out the main shaft I cant remember what the fawk you call it, then put a 4x4 tailhousing on. It would be easier to start out with a 4x4 manual and going with a 1350 or 1354
