After finally growing tiard of spring wrap and not just wanting to build an anti wrap bar I decided it was time to link the rear of my EB. I thought about it a lot and finally decided that I would try out a triangulated upper link and long lower links. A few rules I put in place for my project were to keep the stock width axles, get at least 4" of rear stretch and be able to mod the sheet metal when done to retain clean factory like lines. Yea, I like sheet metal and since the Bronco is in need of new quarters I figured that was a good excuse to stretch it out a bit.
So I finally located all my link mounts and finished welding the links. I still have to add the double shear mount on the inside of the frame for the upper link mounts at the frame. The front frame crossmember is 2x4 x 3/16 box tube with 1/4" plates welded at each end with nuts welded to the inside of the plate for bolting it on. I thought that I would weld it on origionally but looking closer I dont think the tcase will come out with the xmember there. The control arm plates are 1/4" plate mounted on 12" centers for a bit of double triangulation. I origionally had the lower links on the outside of the frame but had way too much roll steer angle, somewere around 12 degrees. I played around with the calc a little more and decided to inboard the lower links at the frame and lower the mounting point. The 4link calc now shows 119% antisquat and 3degrees roll steer angle.
Now its time for springs and shocks and get this thing back on the ground. I will be adding a sway bar to the front for on road stability since it will be coil all the way around and I havent decided what type of bar to use in the rear, maybe Currie front and rear??? Im also going to build a new aluminum fuel tank to accomidate for the diff cover and brackets but the tank is staying in the stock location.
Here are some pics
Here are some pics
