Engine swap - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-07-2007, 07:12 AM   #1 (permalink)
Thumper09's Avatar
Member # 81249
Send a message via AIM to Thumper09 Send a message via Yahoo to Thumper09
Engine swap
I know this maybe a newbie question but before I buy the truck. Will a 351W bolt to a inline 6 tranny. The tranny is a 5 speed so I am guessing a N435 without looking at the truck, am I right or wrong?
Thanks for any help
Dustin
Thumper09 is offline   Reply With Quote
Old 06-07-2007, 07:21 AM   #2 (permalink)
Member # 31425
Send a message via AIM to Ramboss429 Send a message via MSN to Ramboss429
The engine will bolt to the tranny, not 100% sure on the engine mounts though. NP435s are 4 speeds. Depending on the pickup its a mazda 5spd or a ZF 5spd.
Ramboss429 is offline   Reply With Quote
Old 06-07-2007, 07:59 AM   #3 (permalink)
Thumper09's Avatar
Member # 81249
Its a 84 f-150 but it maybe a four speed, thanksfor clearing up the tranny problem.
Old 06-07-2007, 06:14 PM   #4 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Send a message via AIM to svt150j49
the motor mounts are diffrent, but bolt in the same location. if you buy the motor mounts for the same year truck with the 351 it should all bolt up. you have to get a flywheel and diffrent starter if i remember correctly, but the clutch should be the same. at least thats the deal on my 89 6cyl to the 91 v8
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread:
Here
The un-named buggy - 2.3L, lotsa tube, and FJ80s.
svt150j49 is offline   Reply With Quote
