I took my t-case out today there is a round tube between the case and tranny does that mean i have divorced or married it had 32splines, i need to know so i can buy a seal kit. Has any body ever cut this tube and rotated it to clock the case so you don't lose spline engagement.postpics.
if you consider the "round tube" is called the tailhousing part of the transmission then it does in bolt directly up.
if you want to clock it look at redrilling the bolt pattern onto the transfercase rather then chopping the tailhousing up.
the alignment of the shafts is something you do not want to mess up.
the alignment is set by machining in the tailhousing, the transmission side locates on the OD of the outputbearing and the transfer case is located by the input bearing retainer index.
