what trans did you have in there before? If you had a AOD, or C6, I dont think that would cause any issues.
Stupid question, but have you checked for vacuum leaks? When you check for codes, do you get any at all? (you should be at least getting 4 1's(v8) and two 11's) If you arent getting anything at all, something is double not right. When you say no "odd" codes, I assume you are gettin the normal ones? Will it run well enough to give you codes while the engine is running?
- does it run like crap - or is the idle hunting up and down ? - or both - older systems will not give a koer right away - sometimes it takes days - im assuming it ran good before the tranny swap ?
are you running the 83 cam ?? it might not compattible with the factory efi
