i'm after some 9" caliper mounts, i'm planning to run the 1/2 Ton GM brakes wondering who's a good supplier, don't care how they mount bolt on or weld any suggestions?
I want bolt on stuff with Ford parts. Have two 9"s to up grade.
I also want to go with the e-brake option.
I have some parts from an 8.8 that will work with one axle. I've seen write ups on some used parts that will work also.
Bu if weld on turns out to be better might go with that.
I just cut mine out of 3/8's plate with a plasma, and burned them on, but then I found the speedway motors brackets... which are dirty cheap, and we have put them on 5-6 axles in the last few years, and they work perfect(used them on 8.8, 9" and 44's)
i originally did that too. gravelmakers is 35 bucks for both, and the thickness and quality is much higher. my AA brackets (like speedways) is only 1/4 inch stamped shit steel. one of the threads ripped out making me repair it, or weld another on there. just check them out. they are beef. i only use his brackets now.
