1996 F-350 running gear - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2007, 12:26 AM   #1 (permalink)
Member # 63076
I'm thinking about buying a 1996 f350- powerstroke, 5 spd. I know the tranny is a zf but i know nuthin about the t-case. What is it? How strong? Also the front axle appears to be a ball joint d-60? I've had king p 60's before are they similar in strength? What are the likely gear ratios in this truck?
drknyght is offline   Reply With Quote
Old 07-02-2007, 07:05 AM   #2 (permalink)
Oilfield Trash
Red Chevy's Avatar
Member # 64526
t-case should be BW-1356, adequate for the truck depending on what u will use it for. Front axel is a balljoint d60 only difference is the balljoints, strength is the same, some have broken the ball joints in some extreme use depends on what u will use it for. Rear is a sterling 10.25 very strong. 3.55's or 4.11's
'91 k3500, 454, 4speed, 42" R-1's no lift
'97 z-71, 3" BL, 38" tsl radial, 454/th400
'97 tj, 2.5/auto, rubi 44/5.13/spartan, 8.8/5.13/spool,
34/10.50/16 ltb
Red Chevy is offline   Reply With Quote
Old 07-02-2007, 10:49 AM   #3 (permalink)
Newbie
Member # 46117
I believe they also came with the BW-4407. Stronger than the 1356.
91 f150 d60/sterling 10.25 with some other crap
03 f250 7.3
Mr. Death is offline   Reply With Quote
Old 07-02-2007, 12:25 PM   #4 (permalink)
skipped_Link's Avatar
Member # 37865
Correct, the BW-4407 was also avialable in these trucks, & is considerably stronger, just look at the rear output, if it is a slip yoke it is a 1356, flange it's more than likely a 4407.
skipped_Link is offline   Reply With Quote
Old 07-02-2007, 01:46 PM   #5 (permalink)
Member # 63076
What was the low ratio in these BW cases?
Old 07-02-2007, 03:55 PM   #6 (permalink)
RawPower's Avatar
Member # 43894
2.69:1
edit: for the 1356
1993 F350 7.3 IDI, ZF S5-42, 205, Rocks, 145" wb.
Wanna buy it?
RawPower is offline   Reply With Quote
Old 07-04-2007, 07:03 AM   #7 (permalink)
Member # 71793
i don`t know about strength wise but my 96 w/460 has the 4407
MARF75 is offline   Reply With Quote
