f250 4x4 I beam to solid axle??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-22-2007, 03:40 PM   #1 (permalink)
Member # 83247
The search feature isn't working for me, but I need to know if there are kits to swapping out the ttb 4x4 front end out from under my grandpa's f250 for a solid axle? most likely a dana 60? what is the rear end? Or is there any guides online to doing it? looking for more lift so the i beams wont cut it.
mustangsvo85 is offline   Reply With Quote
Old 07-22-2007, 03:42 PM   #2 (permalink)
Member # 50971
no kit onbolt all the old shit and bolt up the d60 they are the same truck.
fordnut is offline   Reply With Quote
Old 07-22-2007, 03:50 PM   #3 (permalink)
Member # 83247
i'm assuming a dana 60 from a f350 of similar year will work? what about driveshafts and steering? I would like a lot of lift since this truck will not be hauling a boat anymore, maybe 10-12 inches? is that possible with the stock leaf spring mounts and a dana 60?
Old 07-22-2007, 04:19 PM   #4 (permalink)
Member # 45530
you solid axle will bolt up to the leafs on your ttb, pull old shit out, put new shit in. Lift depends on the spring and hangers you put in. Lower hangers = more lift, taller spring = more lift, take Advil for any headache's, Midol for any cramps as you may hurt yourself while trying to understand what I've just said
Panthers65 is offline   Reply With Quote
Old 07-22-2007, 05:53 PM   #5 (permalink)
Member # 95344
how much for your front ttb? the reason i am doing a 2wd to 4wd on a van
madskycc is offline   Reply With Quote
Old 07-22-2007, 06:41 PM   #6 (permalink)
Member # 44108
Get yourself a Sky manufacturing shackle reversal kit (should be like 5")...then some 6" F-350 lift springs.
Then get crossover steering and make a trac bar (the factory type sucks).
[center][SIZE="4"][url]Shop.FarmboyFabrications.com[/url][/SIZE]
[B][SIZE="6"]
[COLOR="DarkRed"]239.337.LIFT[/COLOR][/SIZE][/B]
[SIZE="4"]
[COLOR="Silver"]One Up Offroad[/COLOR][COLOR="DarkRed"] Rize Industries [/COLOR][COLOR="Silver"]Icon Vehicle Dynamics [/COLOR][COLOR="Yellow"]RCD[/COLOR] [COLOR="Silver"]Full-Traction[/COLOR] [COLOR="darkred"]Rubicon Express [/COLOR][COLOR="Navy"]KING[/COLOR][COLOR="DarkRed"] Sway-a-Way[/COLOR][COLOR="Navy"] FOX[/COLOR] [COLOR="Silver"]Dynatrac[/COLOR] [COLOR="Indigo"]Yukon Gear[/COLOR] [COLOR="DarkRed"]ARB [/COLOR][COLOR="Silver"]Detroit[/COLOR] [/SIZE]
Including the largest selection of tires and wheels that you will find. Don't see what you are looking for? Give us a call.[/center]
bigreen is offline   Reply With Quote
