np 208- good or bad? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-10-2002, 09:36 PM   #1 (permalink)
Member # 1481
what's the low range? is it strong enuff for my 3200lb b2? it's behind a 351 and c-6 so i assume it has some strength. isn't there a doubler for it or that can be made out of it? no luck on search.
thanks
shon
researching my next mistake....
shons b2 is offline   Reply With Quote Quick reply to this message
Old 06-10-2002, 09:57 PM   #2 (permalink)
Member # 2139
Send a message via Yahoo to FordPowr
2.62:1 low range. I suppose you could put a 203 range box in front of it since it uses the same spline count and pattern as a Ford 205...but the 208 range box doesn't seperate from the chain drive part so it'd be alot of work to use just it's range box.
FordPowr is offline   Reply With Quote Quick reply to this message
Old 06-10-2002, 10:03 PM   #3 (permalink)
Member # 1481
thanks. been awhile since i've been on the boards. i got numbers going thru my head. can't seem to remember the good from the bad.
shon
Old 06-11-2002, 12:02 PM   #4 (permalink)
Member # 6708
Np-208=Good.
It is a good t-case, just make sure it never goes low on oil. With the Auto and the light BroncoII it should hold up fine.
Drain the oil and look for metal shavings. If posible see if the chain has much slop in it thru the drain/fill holes. If the chain has stretched then it'll eat the aluminum case up.
Eric
'There will be pork in the tree tops by morning!'-Lion in Winter.
'Dear,dear.....what ever shall we do with mother.'-Lion in Winter.
"Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson
'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!'
Alpo is offline   Reply With Quote Quick reply to this message
