Mounting sliders to a C-channel frame - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2007, 04:37 PM   #1 (permalink)
mjlogan88's Avatar
Member # 23553
Bolt on or weld on?
I've only put sliders on Toyotas and unibody jeeps and just plated the frame and welded them on. Getting ready to put some sliders on my ranger and am not sure wether to bolt them on or weld them to the frame. A buddy who races desert told me not to ever weld on the Ford c-channel frames. Supposedly the frames are heat treated and welded area will be weakened. Yet I have seen people welding the crap out of ranger/fullsize ford frames with what seems to be good results.
I'd like to just weld them on, but dont mind taking a little extra time to drill some holes if it is going to make a difference.
[QUOTE=davey2451;8082797] i just looked at mjlogan88's ranger and it sucks [/QUOTE]
If all else fails, immortality can always be assured by spectacular error
mjlogan88 is offline   Reply With Quote
Old 08-07-2007, 04:48 PM   #2 (permalink)
Banned
Member # 48208
Weld on.
f250crawler is offline   Reply With Quote
Old 08-07-2007, 05:04 PM   #3 (permalink)
Member # 34322
Not sure about the heat-treating, but the ones i made are bolted on with a backing plate.
RanJerEDGE is offline   Reply With Quote
Old 08-07-2007, 05:21 PM   #4 (permalink)
Member # 10063
Originally Posted by mjlogan88 View Post
Bolt on or weld on?
He's correct in that you shouldn't weld them on, but for the wrong reason.
The frames aren't heat treated (in any way that I can see anyway), but they do flex a lot.
If the rigid slider is welded to it, as things try to flex, it can eventually crack the frame where it's welded.
I would bolt them on.
Here's how I did mine (click for big):
(yeah, that front mount is a bit feeble (too lazy to redo it better), but so far it hasn't let me down (I can still easily do the Hi-Lift under it).
The middle mount on the bodymount bracket is VERY rigid though (easily making up for any feebleness of the front one). There is a huge crossmember that runs right behind there to the other side. It deflects probably less than ½" there when jacked up by it.
'90 Bronco II, 2.9L, Dual T-case, 5.13s, 35x12.50s
[url]http://www.cardomain.com/ride/702959[/url]
4x4junkie is offline   Reply With Quote
Old 08-07-2007, 05:45 PM   #5 (permalink)
Shadowfox's Avatar
Member # 79169
Send a message via AIM to Shadowfox Send a message via Yahoo to Shadowfox
noob question but can't u do both?
[COLOR="Red"]"If it won't fit force it! - If it breaks it was no good anyways"
[/COLOR]
Shadowfox is offline   Reply With Quote
Old 08-07-2007, 09:17 PM   #6 (permalink)
Member # 29794
Send a message via Yahoo to willys101_4lo
Doing both defeats the purpose of the each method. However, as a noob you CAN weld and bolt the sliders on. When you need to remove them to repair them, or repair your now cracked frame, be sure and use the big grinder, its much quicker than simply unbolting things.
The whole "If the rigid slider is welded to it, as things try to flex, it can (and IMHO, will) eventually crack the frame where it's welded" statement totally answers the question as to why you would be better served by bolting the sliders on.
My .02 worth, if you do listen to good advice and bolt them on, don't go cheap on your fasteners. I would personally use at least 4 3/8" bolts on each plate, and as I'm a stickler for bolts, I'd go buy new grade 8's. But if you want to bolt your sliders on with 2 1/4" bolts you found in the bolt set you bought at harbor freight, you CAN do that too. Don't be surprised when those bolts break on you while you try to lift the truck with that hi lift
[QUOTE=beater82;10834814]200,000,000 privately owned firearms in this country and you think we're gonna' run to your frozen ass nanny state to get away from that fuckin' socialist pimp? What the fuck do you think we are? Descendants of the french?[/QUOTE]
[QUOTE=Elwood Blues]Blessed Lady Of Acceleration, don't fail me now![/QUOTE]
willys101_4lo is offline   Reply With Quote
Old 08-07-2007, 09:20 PM   #7 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
Send a message via AIM to svt150j49
just weld it.
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:
Build thread:
Here
The un-named buggy - 2.3L, lotsa tube, and FJ80s.
svt150j49 is offline   Reply With Quote
Old 08-07-2007, 09:29 PM   #8 (permalink)
MASTER TECH
f250rollinon37s's Avatar
Member # 54844
weld it - do it right with bracing and it will not crack. but bolting will work too .
BSW Racing, Calrocs Super mods 12 & ?
Driver: Aaron Whitehead - Driver: Joe Hutchins
Spotter: Adam Kovarik - Spotter: Dustin Knight
Crew Cheif: me fuckers
build up of the truggy
/forum/ford/544813-update-pics.html
f250rollinon37s is offline   Reply With Quote
Old 08-07-2007, 09:40 PM   #9 (permalink)
WHITE RHINO's Avatar
Member # 71446
Send a message via AIM to WHITE RHINO
jb weld it
(WHITE RHINO)88 Ranger, 2.9liter,1350/1354 doubler, HP 60 with Plated knuckles, chromos, PSC Hydro, 3 link, Rear Eaton 44" Pitbulls on H1's
Section8Krawlers.com
Extreme Dual Sport Tuff Lites Unbreakable Turn Signals for your Dual Sport/Adventure Bike
WHITE RHINO is offline   Reply With Quote
Old 08-07-2007, 09:41 PM   #10 (permalink)
loveshackle's Avatar
Member # 9925
Box the frame, then weld 'em on...
Do it once, do it right, & avoid the frame flex.
"All great change in America begins at the dinner table" ~ Ronald Reagan
loveshackle is offline   Reply With Quote
Old 08-07-2007, 11:47 PM   #11 (permalink)
Member # 71446
its all about frame flex
Old 08-08-2007, 10:27 AM   #12 (permalink)
mjlogan88's Avatar
Member # 23553
shit thats where half my flex comes from. better bolt them on.
Old 08-08-2007, 10:49 AM   #13 (permalink)
Nate C's Avatar
Member # 694
I would bolt them on....
X2
michaelsavage.com
Nate C is offline   Reply With Quote
Old 08-08-2007, 11:10 AM   #14 (permalink)
Damn you chuckie...
svt150j49's Avatar
Member # 85316
ha! mines about 75% frame flex
Build thread:
Here
Old 08-08-2007, 11:14 AM   #15 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
I would have to agree with the bolt-on statement Logan. When I would jump the parts trucks on old Camden Ave I could see the frame deflect at least a few inches on impact.
I would definitely bolt sliders to a c-channel frame. You could box it or add some rigid through-mount cross members, however that defeats the cheap build up concept.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
Project Flat F***er (Fender)
Project SR5.0
FordFascist is offline   Reply With Quote
Old 08-08-2007, 12:35 PM   #16 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
Bolt on or weld on?
what does pete know?
hes the shock god ... not the frame god
going back to the basics
Originally Posted by ZukIzzy View Post
Oh and Frequency is for radios
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote
Old 08-08-2007, 01:03 PM   #17 (permalink)
mjlogan88's Avatar
Member # 23553
so how would you "do things right"?
weld them on by hooking the ground to the axle and fry the brake lines?
Old 08-08-2007, 05:23 PM   #18 (permalink)
Member # 48716
Send a message via AIM to VerticalTRX
Bolt them on, you never know when or why you might need to remove them. I have some pics in my build thread of my sliders and how they are attached(I think). I used a plate under the lower leg of the channel, and some angle brackets that I welded to the frame.
Kickin' it old school: '79 Ford, Q78 TSLs and a Q-jet
VerticalTRX is offline   Reply With Quote
Old 08-08-2007, 07:48 PM   #19 (permalink)
Member # 36399
Weld it and forget it.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 08-08-2007, 09:18 PM   #20 (permalink)
never fear
REDWAGON1985's Avatar
Member # 61115
Originally Posted by VerticalTRX View Post
Bolt them on, you never know when or why you might need to remove them. .
same reason I bolted mine on.
REDWAGON1985 is offline   Reply With Quote
Old 08-09-2007, 06:37 AM   #21 (permalink)
mjlogan88's Avatar
Member # 23553
This is what I thought with my old heep, and I never took them off over the course of about 5 years. I dont think they would have come off, though, they were so mashed up into the unibody sheetmetal
And I appreciate all the opinions. I think i'm going to bolt them on because I'm not sure what i'm going to do with the suspension right now. Loosening a couple bolts is going to be way easier than grinding for days if a link mount needs to go where the slider is.
