'79 pickup breaks suck.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-17-2007, 03:46 PM   #1 (permalink)
Danger_Ranger18's Avatar
Member # 82245
79 f350 d60s
the breaks just feel like, you know how when you grab a woman's breast... it feels like... a bag of sand... well thats what the breaks feel like. no but seriously, they dont stop the pickup worth shit. new master cylinder, new break booser, resurfaced rotars, new pads, rebuilt calipers up front. new shoes and drums out back. are the nearly thirty year old break lines expanding? or is it just gonna stop like shit? im only runnin 285/75s.
1979 F350-460
1997 F350-7.3
Danger_Ranger18 is offline   Reply With Quote
Old 09-17-2007, 04:39 PM   #2 (permalink)
Member # 86147
Have you tried bleeding the brakes??? to make sure fluid is flowing to all 4 brakes, and that there is no blockage anywhere?? 30 years old I could not imagine any rust or dirt every getting in the line. Do you have good vaccum to your booster?? Maybe I should rephrase that, does your motor carry good vaccum? That will make your brake pedal barely move "feel like a bag of sand"...there is not enough vaccum to make the booster work. I have 2 trucks that way...'77 f250's.
UltimateRides is offline   Reply With Quote
Old 09-17-2007, 04:58 PM   #3 (permalink)
Member # 36399
Originally Posted by Danger_Ranger18 View Post
79 f350 d60s
If you got break pads, shoes master cyl. etc etc. That could very well be your problem.
You need to trade that in for shit for your BRAKES.
P.S. If your womans tit feels like a bag of sand. Something is VERY VERY wrong.
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks
95 F-150 6" of lift, SAS 35" BFG's
94stepsideford is offline   Reply With Quote
Old 09-17-2007, 05:19 PM   #4 (permalink)
Member # 82245
yeah the engines got good vacume and i bled the breaks and theres fluid at all the corners but it just wont stop worth a piss.
1979 F350-460
1997 F350-7.3
Old 09-17-2007, 06:05 PM   #5 (permalink)
mj
Member # 1919
change the prop valve
those are great Brakes so you have an issue somewhere
mj is offline   Reply With Quote
Old 09-17-2007, 06:42 PM   #6 (permalink)
Ford Forum Moderator
AZFord4x4's Avatar
Member # 421
Are they in something stock or are they swapped into something else? & if so what's the master cylinder from?
76 F250 Supercab 2wd, undergoing Cummins/ZF5/D80 swap
78 F250 Supercab, 60/70 Doubler & dry rotted 42" TSLs. Waiting yet another rebuild.
3 more 70s supercabs, because you can never have too many spare parts around...
AZFord4x4 is offline   Reply With Quote
Old 09-17-2007, 08:13 PM   #7 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
was the MC bench-bled before being installed? If not, do that, then bleed the brakes and see what happens...
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is offline   Reply With Quote
Old 09-18-2007, 12:10 AM   #8 (permalink)
Banned
Member # 48208
X2 And check to make sure you don't need to adjust the push rod on the master cylinder, I've had to adjust all the ones I've installed.
f250crawler is offline   Reply With Quote
Old 09-18-2007, 12:17 AM   #9 (permalink)
GMCTruxrule's Avatar
Member # 51243
a properly bleed and operating stock brake system should be more than adequate stopping power for your truck.
[COLOR="Lime"][B]1999 Chevy K3500, 5.7/4L80E/14FF/stock/stock/stock[/B][/COLOR]
GMCTruxrule is offline   Reply With Quote
