HP D44 Identification? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-23-2007, 09:45 AM   #1 (permalink)
NorcalVP's Avatar
Member # 3973
I just bought a bare high pinion housing, but have no idea what year and model it actually came from. I found the BOM on the long side tube, but looked it up and it does not show up on Dana's site...
These are the numbers on the tube
7 23 6 B 4 603808 9
Can someone point me in the right direction? This has the weld on radius arm bushings if that helps any.
Steve
97/04 D-Cab Taco 5 speed with Mods
You will pay the price for you lack of Vision.....
NorcalVP is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 11:58 AM   #2 (permalink)
MX489's Avatar
Member # 62257
On the housing right where the yoke is there will be a 44 cast into the housing if it is a 44, it took some scraping off of rust and grime to find mine.
MX489 is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 12:15 PM   #3 (permalink)
NorcalVP's Avatar
Member # 3973
It's deffiantely a HP Dana 44. I just don't know what year/application it came out of. I found the BOM on the tubes, but Dana's site doesn't go back that far.
Old 09-23-2007, 01:17 PM   #4 (permalink)
Member # 94725
this will help you narrow it down
http://77cj.littlekeylime.com/Dana44.htm
79 Ford
TroyM is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 01:26 PM   #5 (permalink)
Member # 94725
if it has welded on coil mounts it is 78/79 style out of a bronco,f100,f150. 78/79 style also has the cast in radius arm c's. Not welded on like the 76-77 style.
79 Ford
Old 09-23-2007, 02:19 PM   #6 (permalink)
Member # 54844
post a pic and we will tell you
[SIZE="4"][COLOR="Red"]BSW[/COLOR] Racing, Super mod & [/SIZE] [SIZE="4"][COLOR="Navy"] Bitten [/COLOR]Off Road, Pro mod[/SIZE]
BSW Driver: Aaron Whitehead - Bitten Driver: Mike Stokes
BSW Spotter: Adam Kovarik - Bitten Spotter: Dan Kovarik - AKA -
: me fuckers :flipoff2:
build up of the truggy
f250rollinon37s is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 03:07 PM   #7 (permalink)
Member # 41933
603808 9
Comes up as a 76 1/2 F-150 with open 3.50:1 gears.
51dueller is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 03:16 PM   #8 (permalink)
Master Apprentice
Member # 56692
same axle im using, slap on disk brakes and it's awesome.
1992 Explorer SAS'ed on HPD44/9" W/ 5.13 Locked F/R 36" TSL-SX on DIY Locks
sn0border88 is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 06:37 PM   #9 (permalink)
Mr.N's Avatar
Member # 1635
Thanks for the link.
This is a great housing to start with!
Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html
Mr.N is offline   Reply With Quote Quick reply to this message
Old 09-23-2007, 09:22 PM   #10 (permalink)
NorcalVP's Avatar
Member # 3973
Originally Posted by 51dueller View Post
603808 9
That's just what i was looking for. Thank you very much...
Old 09-23-2007, 09:24 PM   #11 (permalink)
NorcalVP's Avatar
Member # 3973
I'm pretty pleased. Now I just need to cut off the radius arm mounts, shorten the long side, and bolt up my Chevy outers. (Not to mention find a short side inner shaft)
Thanks for all of the help guys..
Steve
Old 09-24-2007, 08:28 PM   #12 (permalink)
Mr.N's Avatar
Member # 1635
Here is my list of Dana 44 axle shafts. Just the fronts with 297 sized u-joints (aka 5-760x)
http://77cj.littlekeylime.com/Spicer...shortside_.gif
Old 09-24-2007, 08:50 PM   #13 (permalink)
mj
Member # 1919
just start with yukons or similar and save yourself the headaches
mj is offline   Reply With Quote Quick reply to this message
Old 09-24-2007, 09:14 PM   #14 (permalink)
NorcalVP's Avatar
Member # 3973
I've got some alloy USA shafts for a waggy (still need to get bobby longs joints), so I'll only need to get the one inner shaft and I'll be set. But the stock shaft will be a spare.
