Member # 84370
ZF to a 302, help please
i got a ZF S542 4wd 5 speed from a 88 f350 with a 351.
i have a 85 302 that i think was fuel injected but now its carbed. what flywheel do i need? what size clutch? what else do i need? all i have is the tranny and motor no other parts its going into my 88 ranger that was an auto so i cant use anything from that. any info on anything would be awsome, ive looked around on other posts but i cant find what im lookin for. thanks |
Member # 49744
get all the parts for a 88 f150 with a 302 and a zf 5speed. you can either run the 11" clutch or 12" clutch. whatever one you choose to run is up to you. the 351w is the basically the same engine.
[FONT="Franklin Gothic Medium"][SIZE="2"][COLOR="SeaGreen"]after monday and tuesday even the calendar says WTF!!!!!!!!! 96 f350 powerstroke.[/COLOR][/SIZE][/FONT] |
#4 (permalink) | |
Member # 94747
You will need a clutch pedal assembly for the hydraulic clutch in a manual ranger as well. Just make sure you get the flywheel for the 85 302 cuase the flywheel wont make the diff in the trans swap. Or you can take both the 351 flywheel and 302 flywheel and have a machine shop make the 351 have the same balance as the 302 you would be guaranteed it would work. |
Fawkin Fordhead
The M5OD is what came in half tons, not the ZF, but, the clutch/flywheel for an 88 with a M5OD should work just fine with a ZF, and an 82+ 302.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
Member # 84370
so i was lookin at summit racing and they got the zoom 11" clutch kits, should i get the clutch for the 302 or the ZF. cuz they both hav 10 spline shaft and are 1-1/16 shaft size but the one for the zf is 300 and the one for the 302 is under like 200?
and what weight/tooth/size flywheel do i need?. my motor or tranny never came with one. thanks for the help |
