Member # 85265
yeah these guys make a good one http://www.kalecoauto.com/. do you have the cross drilled brake lines? they are good for any 4x4
the beatings will continue until morale improves. |
Hmm, 8.8 = IFS CAD front.... Only way you're gonna get locking hubs is put in a real axle
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
Nope, an 8.8 front is the 8.8 IFS front end found in the F150's, and it's based on the 8.8" Ford rear. The D50 is all Dana.
#9 (permalink) | |
Damn you chuckie...
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
Member # 94747
Does it have auto hubs? If its a 3/4 ttb all you gotta do is go to the junk yard and get some factory hubs and install em. Or if you want good ones WARN Mile Marker superwinch all make hubs for it.
Dont forget those cross drilled brake lines
