fitting 35sp shafts in a d61? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-24-2007, 05:29 AM   #1 (permalink)
jackstand hero
bigjeep85's Avatar
Member # 65233
what do i need to do to put 35 spline shafts into a d61? the 61 is out of a 79 ford f250 4x2. and yes i did a search.
bigjeep85 is offline   Reply With Quote
Old 11-24-2007, 07:33 AM   #2 (permalink)
Member # 29210
Send a message via AIM to Davethorik
try again.
:laughing:
Davethorik is offline   Reply With Quote
Old 11-24-2007, 08:26 AM   #3 (permalink)
jackstand hero
bigjeep85's Avatar
Member # 65233
Originally Posted by Davethorik View Post
try again.
great answer ohh wise ass one. i have read posts from 2002 up to the present and several people say you can put a 35 spline in the tubes because they are larger than the standard 60. but what no one says is how to do it.
Old 11-24-2007, 09:11 AM   #4 (permalink)
Member # 29210
Generally when I install axleshafts into a full floating rearend I slide them in the spindle, wiggle it to match the splines, and then bolt it down. I don't know what you do.
Maybe you should, oh, I don't know, measure your spindles' ID to even see if you can fit 35 spline shafts. Then worry about side gears and having the right length shaft. But you're right, I couldn't find this using search. I was born with it implanted in my skull. Much of my childhood was spent deciphering it, and lo! I found my calling reading this BB. Tabula rasa is complete BS!
:laughing:
Old 11-24-2007, 11:30 AM   #5 (permalink)
jackstand hero
bigjeep85's Avatar
Member # 65233
the spindles are 4.5" (if i remeber right) do you know what the d70 spindles are?
im glad your able to slide full floater axles into the tubes without hurting yourself. you must be proud of yourself.
