Member # 34712
best center section for a 9 inch
After blowing 2 standard centers running 31 and 33 spline shafts, spooled, I need a better center. do I look at a s case, n case or other. Don't really need a high pinion and I am running 4:88 with 37inch tire. It looks like to pinion support is blowing out and the exploding the case.
s |
My friend had the same problem in his cherokee on 37" boggers, he went with the Currie 9+ center and hasnt had a problem yet. He has 35 spline shafts too.
http://completeoffroad.com/wsm/i-32_...ch_ford_9.html Thats the smaller bearing thirdmember, my buddy has the small bearing 35 spline spool. Which allows him to run that 3rd. Normally you need the 3.25 Carrier bearing 3rd to run 35 spline. Heres the 3.25 bearing version. http://completeoffroad.com/wsm/i-34_...ch_ford_9.html Last edited by redranger4.0; 11-28-2007 at 03:57 PM. |
Member # 57166
maybe try running a daytona pinion support?
87 pathfinder HPD44 wristed radius arm, yukons, super joints, detroit True hi9 spooled 4 link 5.38's WH variable rate coils on all 4. |
Damn you chuckie...
i have the nodular Strange 3rd in my truck. no problems yet... it seems to be built very well. if you compair the stock 3rd, and the Strange 3rd, you can see why its so much stronger...
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
Member # 50098
Get the strange N and a billet pinion support. Make sure to get the third that will take 35 spline 3.25 and you will be able to run 31 spline on up to 40. If you run smaller then 35 spline you have to get spacers "cheap" and if you want to go to 35 spline later on you will only have to change the locker and not the third also.
[CENTER][FONT="System"][SIZE="5"][COLOR="Orange"]Copperhead Fab[/COLOR][/SIZE][/FONT][/CENTER] [CENTER][SIZE="3"][FONT="Arial Black"][COLOR="Red"]MY BUGGY BUILDS[/COLOR][/FONT][/SIZE][/CENTER] [CENTER][url]http://www.pirate4x4.com/forum/showthread.php?t=406196[/url][/CENTER] [CENTER][url]http://www.pirate4x4.com/forum/showthread.php?t=569339[/url][/CENTER] |
