Damn you chuckie...
D44 Locker ???s
Im looking at a used Detroit Soft Locker for my front axle... anyway, i know that the TTB has a C clip in one axle shaft... not the other...
so the question is, will the soft locker work on the TTB? or does the C-clip screw it all over? either way, ill get it for the SAS, but im just wondering if i can run it in the TTB until I do the swap. Anyone?
1996 F150 - Supercharged 5.8L, E4OD, Vortech S-trim, PSD Intercooler, 15 psi , 1356, Dana 60, 10.25, 5.13 gears, welded rear diff, 14" Air/Coilovers. Check it out:Build thread: ![]() ![]() Here The un-named buggy - 2.3L, lotsa tube, and FJ80s.
Damn you chuckie...
im assuming thats a "your SOL man..."
ill have to just wait...
Member # 92867
well.....can you find one for ttb years?, that would be a good indication if they will work with them or not...
96' F-150....460/c6/205/200 on rockwells 78' Bronco- 408m, C6, NP205, chromos, 40" boggers.... Last edited by BOGGER1966; 12-07-2007 at 02:00 PM. |
Damn you chuckie...
actually, detroit lists them to fit it. but im confused on how the c-clip works out in it.
so yes, i did find them to "work" with the TTB 44 - smart ass.
Member # 36399
Just do what every other mother fucker does and eliminate the clip by putting a spring on the center slip yolk...TA DA
94 F-150 Stepside. BGTL 12" lift, 1-tons, 39" 'roks 95 F-150 6" of lift, SAS 35" BFG's |
Member # 92867
im sure they aren't going to offer it if they wont work....im sure in the "instructions"...haha, there somthing to tell you what to do...
96' F-150....460/c6/205/200 on rockwells 78' Bronco- 408m, C6, NP205, chromos, 40" boggers.... |
Damn you chuckie...
its used.
Damn you chuckie...
actually i had never heard of that. i think its becaust i never payed attention to TTBs with lockers. thanks. ill be sure to take pictures when it shatters...
MASTER TECH
Member # 54844
just read over a few hundered pages of crap - so -
any hp44 locker will fit in the case. there are 2 versions of the ttb 44 case. there is an early style, that uses 2 bolts that hold a plate / retainer on the axle shaft. locker / ls will fit these without mods. the newer style has a c clip in the case, there are no current locker / ls ( arb and ezlocker are not very clear on this ) that can use the c clip in the factory location. so a common mod is to install a spring in the slip tube in the center u joint to keep the shaft engauged. or a spring on the outside - i have a pic -
BSW Racing, Calrocs Super mods 12 & ? Driver: Aaron Whitehead - Driver: Joe Hutchins Spotter: Adam Kovarik - Spotter: Dustin Knight Crew Cheif: me fuckers ![]() build up of the truggy /forum/ford/544813-update-pics.html |
Member # 26367
I've used the spring in the passengers side axle shaft slip joint trick many times, locker or not, works just fine. It makes changing a broken passengers side axle on the trail much easier. Just be sure that the spring is not to tight & does not limit the axles slip joint travel, the axle slip joint slides in when the suspension is unloaded & could bind up with to long of a spring.
#11 (permalink) | |
Damn you chuckie...
