C4 without kickdown - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-20-2007, 09:38 AM   #1 (permalink)
mjlogan88's Avatar
Member # 23553
C4 without kickdown
Can i run a C4 without the kickdown?
I searched over in the C4 section at fordmuscle.com and it doesnt seem like anyone agrees. Most claim that the kickdown doesnt affect line pressure in the C4, but there are a few that disagree which makes me worry. I'm no tranny expert, but it seems to me the whole idea behind a kickdown is to give full line pressure at full throttle.
Its a C5 with a transgo 40-3 (full manual) shift kit if that matters.
mjlogan88 is online now   Reply With Quote Quick reply to this message
Old 12-20-2007, 10:32 AM   #2 (permalink)
Banned
Member # 36711
If it has a full manual valve body I wouldnt think it would need a kick down. I dont think the kick down has any affect on the line pressure....
Nor Cal Wheelin is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 12:59 PM   #3 (permalink)
Member # 89600
even if you didnt have a full manual valve body, you dont need kick down cable. its vacuum controled. so you can run no kick down cable and be totally safe.
fordori is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 04:00 PM   #4 (permalink)
Member # 87058
The kickdown is just a mechanical version of the vacuum modulator. They control the governer body to delay the upshift. The vacuum modulator delays it under hard throttle to run out the lower gears. The mechanical kick-down manipulates the body in the exact same manner, but it does this so the lower gear leads the acceleration so the tranny doesn't become bound from torque and shift erratically or unpredictably, theoretically that is. Although there will be a minor delay before the modulator down shifts for you, if you remove the kick-down and drive it for a couple of weeks, I'll bet you won't even know its missing. Its probably not the best thing you can do for the tranny, but even on the long list of bad things we do to our rigs, I think this one would be on page 2.
JGVABronco78 is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 04:17 PM   #5 (permalink)
Member # 89600
great explaination
Old 12-20-2007, 04:56 PM   #6 (permalink)
rdnkjeeper's Avatar
Member # 9501
Send a message via Yahoo to rdnkjeeper
I ran without one for years without problems.....
rdnkjeeper is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 05:03 PM   #7 (permalink)
kpj
Member # 6920
I ran one w/out while I had my TJ. No issues.
kpj is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 05:26 PM   #8 (permalink)
brewchief's Avatar
Member # 71185
When I got my c-4 back from my trans guy the kickdown lever was cut off and he told me that I did not need to hook up the vac. mod. This is with a full manual rev. valve body.
Brewchief
brewchief is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 05:42 PM   #9 (permalink)
Member # 87058
Brewchief
That would be correct. Full manual valve body does not route through governor, therefore no input for speed(rpm of output), load(manifold vacuum) or throttle position(kick-down) is relevant to it.
Old 12-20-2007, 07:22 PM   #10 (permalink)
FoMoCo MoFo
Totalled's Avatar
Member # 79002
Location: My little kingdom of awesome. Near Olympia, Thurston county, Wa
Run it.
Tarped lawn art: 1985 BroncoII Eddie Bauer. V8/Automagic/Locked/MTRs.
I want everyone to have everything. I want gays to be able to fuck each other in the ass, in the middle of a field of weed while shooting pistols in the air like yosemite sam shouting that there is no god.
Totalled is offline   Reply With Quote Quick reply to this message
Old 12-20-2007, 09:46 PM   #11 (permalink)
Member # 91931
thats what my truck has right now. it all works just fine.
Gregg_O is offline   Reply With Quote Quick reply to this message
Old 12-21-2007, 08:54 AM   #12 (permalink)
mjlogan88's Avatar
Member # 23553
bitchin thanks for all the replies. good explination JGVABronco78, i appreciate it.
