Member # 11955
One o2 to two o2
IM doing a 5.0 to 5.8 swap and the 5.0 had two o2 snesors and the 5.8 has just one. Is there any way to wire it up so i could use the two o2 sensors instead of having to put the one in because the way my exaust is setup it would have to be way down the exaust sytem and really hard to do.
48 willys pickup on 1 tons, 5.8L and 44's. 01 ford superduty 4x4 6 speed. |
Member # 14848
Who burns truck ECMs? Last I heard, the only ECMs with after market support were the 5.0 mustang and the post '96 OBDII truck ecms...
Later, Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case 1988 Bronco,in progress |
Member # 11955
I didnt want to do that because i want to keep the wiring harnse off this motor sense i gave the other motor and wires to a buddy. I Have all the computer and everything for this one. But what i want to do is wire up the two o2 sensors together so i will get readings from both sides and would be able to plug it into the 351 wireing harnes.
Member # 14848
No, you can't wire the two sensors together, it doesn't work that way. Put one sensor in the Y pipe or H pipe if you have duals.
Member # 14848
Just a side note, you mention in your OP that a single sensor would have to go "way down" due to your exhaust design. If you put it very far from the manifolds/headers the O2 sensor will never work correctly. Worst case scenario put it just down stream of one of the collectors. It will only read one bank that way, but it doesn't make a lot of difference on early FI as the single O2 sensor design adjusts the mixture for all of the cylinders based on its reading. The only way you could get into a lot of trouble is if the bank w/o the sensor got really screwed up... catastrophic fuel delivery issues are not what it is there for anyhow, so I think you will be all right with it in just one collector.
Later, Jason
2006 JCORF Buggy, 60's,Locked F&R,42" TSLs,EFI460,C6,Atlas5.0 Comp Case 1988 Bronco,in progress Last edited by Wicked_S10; 01-05-2008 at 02:40 PM. |
