4x4 no engaging on a 77 ford f250 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-02-2002, 01:18 PM   #1 (permalink)
Member # 12565
Send a message via AIM to thebignasty
im pretty sure its not my transfer case since the front driveshaft turns, i took the old manual hubs off and the drivers side one was ok but i put a new one on anyway. the passengers side hub was broken though and wouldnt lock and the shaft the hub goes on (cant think of the name atm) is bent like its broken or a bearing is out. any ideas as to what my problem is?
btw hi everyone this is my first post
thebignasty is offline   Reply With Quote
Old 07-02-2002, 03:32 PM   #2 (permalink)
Member # 10165
Possibly a broken stub shaft. If it isn't running true there is definitely a problem and it will require disassembly and inspection to determine the root cause. The broken lockout can be caused by a stub letting go!
Steve
TEAM BREAKALL "Wheel with authority!"
Ultim8kaos is offline   Reply With Quote
Old 07-02-2002, 03:36 PM   #3 (permalink)
Member # 12565
thanks man we are gonna tear it down as soon as it stops raining here, if it ever does...
Old 07-02-2002, 08:16 PM   #4 (permalink)
Member # 324
You just explained your problem when you said the hub was broken. If its like the 77 i had with the spicer hubs just junk them and get some Warns. Actually i still have the warns in my garage from that truck.
Family, Friends, riders and racers, its who we are.
smurfsdad is offline   Reply With Quote
Old 07-07-2002, 07:23 AM   #5 (permalink)
Member # 12565
yea i replaced the hubs and a frozen u-joint and that fixed the problem
