brake lines - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-22-2008, 09:36 PM   #1 (permalink)
Member # 75135
brake lines
Ok, I put a reverse shackle kit and a straight axle 60 in my 97 F-250. I have searched everywhere for front extended brake lines. All the ones I can find are different than whats on my truck. The drivers side brake line has a block where a line comes out of the side and goes to the drivers side caliper. Also there is a line coming out the back of the block going to the passenger side caliper.
Anyone know where I can find the correct extended brake line?
P.S. I'm only 34 minutes late for a Tuesday post
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS
N_Rod is offline   Reply With Quote
Old 01-23-2008, 06:41 PM   #2 (permalink)
Moderhater
Halogrinder's Avatar
Member # 16980
your talking about only using one brake line from the truck, down to the axle, and then the brake line splits on the axle to go to individual sides, right?
check autozone. seriously! i got a bitchen, prebent line that was cheap, and fit perfect!
i then got a custom brake line made from keithflux here on the board, but latley he hasnt been making them, so check the vendors forum
Im your BMW huckleberry
https://www.facebook.com/BMWdoctor can you do me a favor and like/share my page? If you like/share, you get free washes/discounts/other neat stuff for you car!
gun facts that will blow your mind:
http://www.gunfacts.info/pdfs/gun-fa...6_1_screen.pdf
Halogrinder is offline   Reply With Quote
Old 01-23-2008, 06:48 PM   #3 (permalink)
Fawkin Fordhead
82F100SWB's Avatar
Member # 15263
Send a message via ICQ to 82F100SWB Send a message via AIM to 82F100SWB Send a message via MSN to 82F100SWB Send a message via Yahoo to 82F100SWB
Nope, I know exactly the oddball setup he's talking about. Hard line comes from the master into a block that is part of the drivers side brake hose(secured to the frame on a bracket same as a TTB F250, same idea as a TTB F150, only a bracket instead of the coil bucket) then it has a flex hose going down to the caliper off of the bottom of the block, and a hard line coming off of one side of the block, and running over to the bracket/flex hose on the pass side. Both flex hoses are secured to the chassis.
As for where to find longer ones, I have no clue.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making
96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig
92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig
86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build
82F100SWB is online now   Reply With Quote
Old 01-23-2008, 06:57 PM   #4 (permalink)
Moderhater
Member # 16980
hmm. couldnt tell you. still vatozone might be the ticket.
Old 01-23-2008, 07:02 PM   #5 (permalink)
Moderhater
Member # 16980
heres a crappy pic, you can see my brake line setup....
Old 01-25-2008, 02:48 AM   #6 (permalink)
Member # 75135
Thats exactly what I have. I am going to call skyjacker todday and check with then. Thanks
