Building a full hydro steering from scratch - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-27-2008, 12:32 PM   #1 (permalink)
colbyhunt's Avatar
Member # 46719
I am going to build a full hydro steering. I want to build it from scratch. I having troulble finding a place to start. I want to do a double ended ram but from there im not sure where to go. The requirments is I want to build from parts from something. Like forklift tractor combine etc. I just was wondering if there is one of these that is better than other.
76 Bronco 42 pitbull rockers , tons, linked, co's
colbyhunt is offline   Reply With Quote
Old 01-27-2008, 12:49 PM   #2 (permalink)
mj
Member # 1919
surplus center sells everything you need
it is cheaper to just buy a kit from the 'names' on this site.
whatever Station company is called would be very high on my list, or rockstomper as I like the ram they use.
mj is offline   Reply With Quote
Old 01-27-2008, 01:03 PM   #3 (permalink)
colbyhunt's Avatar
Member # 46719
I been looking at those what are people running and are some of them set up to self center
Old 01-28-2008, 07:32 AM   #4 (permalink)
Member # 100759
Re
I just put full hydro steering on my pulling truck. My application is a little different than a rock buggy, but I used an Char-Lynn orbital valve from a forklift, an electric hyd. pump/resoviour from Force America and a 2"x8" cylinder from the local Tractor supply store. I made a new tie rod from 1-1/2" .25 wall DOM tubing and Heims endsand fabricated the tabs to weld to the axle and tie rod for the cylinder.
I do have to agree with the other post above though, It would be easier for you to buy a kit from a supplier though as I had to do a lot of fab work that was only possible because I have access to a fully equippped tool and die shop. Also the orbital was FREE, so that made it easier when I had to fabricate the steering shaft cuz I couldn't find one to fit the orbital I had.
Alan
Loganwildman is offline   Reply With Quote
Old 01-28-2008, 04:53 PM   #5 (permalink)
HOT_DAMN's Avatar
Member # 66873
I got my orbital out of a forklift at a scrap yard for $25. Orbital came with a steering colum that a modified to fit on to my truck. If you do your research you can find out the flow rate and the other numbers that you need to determine wich ram to buy. As far as pumps, I plan on running my stock saginaw pump with a remote resivor. If you do your homework you can design a good setup on the cheap, just takes a little more time than buying a whole set up, some of us dont have 1200 to droop on a steering system.
Try sercing, and read the tech section on this website, there is a good write up in there about full hydro.
HOT_DAMN is offline   Reply With Quote
Old 01-28-2008, 06:06 PM   #6 (permalink)
colbyhunt's Avatar
Member # 46719
Thats what Im wanting to do is get a orbital form a forlift and fit the right ram. I was just looking at surplus center and thought that i could do it pretty cheap from there. I didnt know if there is a forklift or some equipment that was better than others
Old 01-28-2008, 09:26 PM   #7 (permalink)
lil-bronc's Avatar
Member # 21881
I bought from PSC when they had a sale...
A friend, went to forklift yard. Kind of like pick'n'pull, and he put a full hydro steering for about half the price. But, he was patient and waited for what he needed.
just a few cents of mine.
Just trying to keep up with the Jones'.
Team Ram Rod - 91
KOH 2012
lil-bronc is offline   Reply With Quote
Old 01-29-2008, 07:51 AM   #8 (permalink)
Member # 100397
performanceoff-road.com is a great company to work with.
zdaily is offline   Reply With Quote
Old 01-29-2008, 08:22 AM   #9 (permalink)
wheelin66bronco's Avatar
Member # 44308
I built my whole steering system from surplus center parts, everything accept the Howe pump.
If you want the info, I can look at my reciept for the part #'s.
No wheelin rig right now.
98 QCLB 4x4. Built 47RE, Bags, Guages, Pumped up, Exhaust, TW Guard Dog 35's, Ford knuckles/hubs.
Looking for 1996 Ford Bronco
05 Dodge free-spin conversion /forum/dodge/880388-my-diy-2005-dodge-dually-4x4-5-9l-free-spin-kit.html
Originally Posted by broncolou View Post
LS motors are like tampons....every VAG has one!
wheelin66bronco is offline   Reply With Quote
Old 01-29-2008, 09:15 PM   #10 (permalink)
Member # 40162
I notice you are from Illinois, so you should also consider a steering valve from a combine or other agricultural application. Massey combine valves seem to be a popular choice in the group I wheel with here in Iowa.
"Time you shut your cake-hole, YOKO!!!"
wyldstallyn73 is offline   Reply With Quote
Old 01-30-2008, 07:23 PM   #11 (permalink)
colbyhunt's Avatar
Member # 46719
a massey combine would be a great choice for me. I know I can get one from something like that I just dont know which one would be the best. I thought it would be cool to do it that way.
